Streaming to remote devices??
Postby quandary » Sat Aug 01, 2009 2:59 am
Website lists controlling multiple devices through web interface.
What is the syntax for streaming urls?
for instance, what url to i point my squeezebox(or any streaming receiver) to so i can send it music with subsonic. can i specify the player name in the web interface with the url? (unix geeks: I need man page)
Thanks for your help.
quandary / Tim
quandary
Postby sindre_mehus » Sat Aug 01, 2009 9:01 pm
You can try something like this:
http://<server>/subsonic/stream?player=1
(change player ID accordingly). Also configure the player in Subsonic to be of type "External". Add entries to the player's playlist via the web interface, then connect the Squeezebox.
Hope it works :wink:
Almost
Postby quandary » Sat Aug 01, 2009 9:15 pm
gives 2-3 seconds of audio, then disconnects. I know its not a network problem (gigabit E) and the flash player works fine
quandary
Postby kwonline1 » Mon Jan 03, 2011 8:56 pm
Here a Solution
1. Add an external Player in Subsonic (with or without Playlist)
Name it "Squeeze"
unselect "Control Player automatically"
let all other settings by default
2. Select Player "Squeeze"
3. Add some Songs to the Playlist an click "Play"
4. In SqueezeCenter go to Internetradio and open URL:
http://<yourServer>/stream?player=<id of your SqueezePlayer>&suffix=.mp3
eg:
http://192.168.1.10:8003/stream?player=18&suffix=.mp3
kwonline1
