How can I adjust played counter for specific album
Postby kdid » Wed Aug 05, 2009 6:07 pm
I have some albums that have counters that is to hi due to experimenting some on playback of the albums tracks. Now I want to adjust some of them to a more correct level.
Is there a way to do that? I believe I will need to adjust it in the database file subsonic.data, but I am not sure how to do that.
Anyone that knows how to?
-- kdid
kdid
Postby kdid » Wed Aug 12, 2009 9:13 pm
Bump
Is there anyone that knows anything about this?
-- kdid
kdid
Postby jonathanroz » Thu Aug 13, 2009 9:09 pm
Login as admin
Go to the url bar at the top of yoru browser and replace "index.view" with "db.view". For example http://yourserver/subsonic/db.view
This will give you a new page
Enter
select * from music_file_info
and press OK
This will give you a list of all your music folders
Then find the ID (the first column) next to the ablums you want to update and enter the following command.
Of course you will have to use the actual ID of your album instead of 555 as well as whatver play count you want.
UPDATE music_file_info
SET PLAY_COUNT = 0
WHERE ID = 555
jonathanroz
Postby kdid » Fri Aug 14, 2009 9:33 am
Thanks a million. That worked just fine. :-)
-- kdid
kdid
Users browsing this forum: No registered users and 35 guests
