java and FreeNAS
java and FreeNAS
Postby bixtool » Sat Aug 22, 2009 1:48 am
I am trying to setup subsonic on FreeNAS 0.7rc1. I cannot get Java installed.
I use this command: pkg_add -v /mnt/Media/tmp/diablo-jre-freebsd7.i386.1.6.0.07.02.tbz
Installation proceeds, but fails: " write failed, filesystem is full" for several entries.
I had this problem initially: "PKG_TMPDIR environment variable to a location with at least 109M bytes"
Which I fixed with a command I found somewhere: "setenv PKG_TMPDIR /mnt/Media/tmp"
Yet I still cannot install java. This is a full installation.
Can someone help here?
bixtool
Postby jigsaw » Sun Aug 23, 2009 1:23 pm
jigsaw
Postby sgx1 » Mon Aug 24, 2009 9:22 pm
How big did you make the boot OS partition? Even if you change the PKG_TMPDIR, the package itself will be installed on the same partition as FreeNAS.
sgx1
