I search grab/ripp Tool with specialy functions
Postby deejay2302 » Sun Oct 18, 2009 9:47 pm
So i search a grab/ripp tool so recode my Musiccollection.
Sample: MP3 File 192 Kbit/s ripped and i will ripp all my collections to 160 kbit/s.
C:/Music/Top/Orginal MP3 192 kbits
encode to 160 kbits and replace C:/Music/Top/Orginal MP3
I will Drag the folders with sub-folders to program and encode all Files in the folders and sub-folders and replace the orginal files.
U understand what i mean ?
The problem is... i must copy all files to one folder for Ripp-Process!
I search a program what ripp files in the orginal folders and which the original files replaced.
I can not Copy all my files to one folder!!
That would mess up my whole order. I would like to avoid. And over 300,000 files that would be a great chaos.
I would like to reduce the download time, while I make the files smaller.
Does anyone know such a program?
deejay2302
re
Postby pcs800 » Wed Oct 21, 2009 3:15 am
I think we are having trouble understanding what you mean by "I can not Copy all my files to one order".
What does this mean?
You need a program that will convert 192kb/s mp3 files to 160kb/s? is that all?
pcs800
Postby deejay2302 » Mon Oct 26, 2009 11:33 pm
No thats not all^^
Sorry for tha last text. I mean Folders, Not Orders^^
The program should be able to edit individual folders. And at the same time.
I would not just have to copy each folder to grab individually.
The program should, in principle, can process multiple folders in a list.
That is what i mean^^ . Grab-programs I know plenty, just not with such a function.
An Idea ?
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
re
Postby pcs800 » Mon Oct 26, 2009 11:43 pm
Acosutica mp3 cd burner and audio converter pro will rip music into individual folders. www.acoustica.com
pcs800
Postby deejay2302 » Tue Oct 27, 2009 4:11 pm
Thanks for the Answer. Sry this is not that what i search.
Acoustica Ripp the Files to another selected Folder. :( Its the same what all other programms can do.
What i mean....
I will this Folders grabb as one Step
I:\Musik\Folder 1
Track 1 <-grabb / delete / replace (before: 320 kbps, after 160 kbps)
Track 2 <-grabb / delete / replace (before: 192 kbps, after 160 kbps)
Track 3 <-grabb / delete / replace (before: 320 kbps, after 160 kbps)
I:\Musik\Musik New\Folder 2
Track 4 <-grabb / delete / replace (before: 250 kbps, after 160 kbps)
The command would be as follows:
Grabbing in process....
Delete orginal files in the folders...
Replace the orginal files in the orginal folders...
Done!
I will grabb all Folders to Orginal Folders include the Sub-Folders
The music files here should be grabbed in the same folder where the original files are.
That is what i mean.... :-/
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Postby kdid » Thu Oct 29, 2009 10:41 am
MediaMonkey can do it. (It might be one of the features that expires after 30 days though if you do not buy the program.)
In the Tool/Convert dialog you can select to replace the original files.
www.mediamonkey.com
PS. Are you doing this because you have limited space for your music collection?
I would not recommend you to lobotomize your collection in this way to get room for more music.
To convert from CD->192->160 will not be as good as converting directly from CD->160.
I would instead bought me a bigger harddrive, or remove other stuff not needed. But then, most of my music is in (lossless) FLAC.
-- kdid
kdid
Postby deejay2302 » Tue Nov 24, 2009 12:36 pm
The problem is i have Subsonic on my computer. And i must buy new Hard Drives for more music. MY Music Data is over 300.000 Files. Subsonic and becomes slower with so many files. I have no idea whether it Subsonic is located, or on my PC. My System Requirements are 2.8 GHZ Dual Core and 2 GB of Ram. Unfortunately, I do not have anything to music on CD, so I have my songs get a little smaller.
I'll look at me the program once more. Thanks for the tip. :wink:
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
