SubAir behind SSL prompts for certificate
Postby omatzyo » Fri Feb 19, 2010 3:32 pm
When using SubAir to connect to an address behind SSL, the application constantly asks to approve the certificate. This occurs during every transaction between client and server if the certificate is not trusted.
Sindre, can you add a feature to approve a certificate only once for the entire session?
omatzyo
Postby flacflac » Sat Feb 20, 2010 11:13 am
I actually asked the SubAir developer to try and fix this issue in its own thread, as I think the certificate management of SubAir is the issue.
http://forum.subsonic.org/forum/viewtopic.php?t=2671
If you figure out a solution please post it here - SubAir is currently unusable for me, too. :?
Thanks.
flacflac
