Display Embedded Album Art in MP3
Postby diab0lik » Tue Mar 23, 2010 12:31 pm
is there a way to display embedded album art? it seems that subsonic only picks up jpgs in the folder
diab0lik
Postby deejay2302 » Tue Mar 23, 2010 6:30 pm
Read here on www.Subsonic.org text
Subsonic Features:
Displays cover art, including images embedded in ID3 tags.
Unless I am mistaken, then extract the images from the Subsonic mp3's. Which are invisible in the folders?!
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Postby diab0lik » Wed Mar 24, 2010 12:50 pm
my mp3s have images embedded in the id3 tags. i just can't get it to display when i play using subsonic. mediamonkey reads the images fine
diab0lik
Postby Pathduck » Sat Mar 27, 2010 6:58 pm
diab0lik wrote:my mp3s have images embedded in the id3 tags. i just can't get it to display when i play using subsonic. mediamonkey reads the images fine
Check in Mediamonkey if your embedded images have Descriptions. That was a problem for me - Subsonic got an exception trying to parse images with descriptions. I reported it here:
http://forum.subsonic.org/forum/viewtopic.php?t=2897
Do you get the "No Coverart" image or the browser "X" for no image found?
Pathduck
Postby thomasbruce » Mon Apr 12, 2010 2:40 pm
Pathduck wrote:
diab0lik wrote:Do you get the "No Coverart" image or the browser "X" for no image found?
i have the same problem, some show the no coverart image and som show the browser "x" or in safari "?" for no image found. all of my mp3's have coverart.
i have added some coverart myself and some downloaded with itunes but i've used a script to embed itunes art into id3 tages. does itunes art come with description? can that be the problem?
would like to find a way to fix this! anyone?
thomasbruce
Same Problem
Postby stoneym » Fri Apr 30, 2010 9:52 pm
I have the same issue. I manage my music in itunes. And I use TuneUp to get missing album art, etc. All album covers are visible in iTunes and on my iPhone. But Subsonic seems to drop album covers at random.
stoneym
