[SOLVED] Problem with french characters
Postby Stab » Thu Apr 08, 2010 9:54 am
Hi !
I've just installed subsonic on Debian Etch and it works fine except, that it can't play songs with chracters like àéèç.... which are replaced by �...
I searched on the forum how to solve it but I am a totally newbie and I don't understand what I should do...
Thanks for this wondeful application !
Edit : Ok I solved by putting UTF8 in the web.xml file
Stab
Postby sindre_mehus » Thu Apr 08, 2010 1:48 pm
Where did you put UTF8 in the web.xml?
Postby Stab » Thu Apr 08, 2010 3:48 pm
I put UTF8 here <?xml version="1.0" encoding="UTF8"?> but i changed it many times so I can't remember what was there in the first time !
But finally I still got the same problem, I have to run dpkg-reconfigure locales after each reboot to solve it :(
Stab
Postby flacflac » Fri Apr 09, 2010 8:34 am
@Sindre: I think the same issue was mentioned here before -
http://forum.subsonic.org/forum/viewtopic.php?t=2246
Any chance for a fix in 4.0? :)
Thank you,
ff
flacflac
Users browsing this forum: No registered users and 42 guests
