please help me
please help me
Postby paul1977 » Sun Apr 25, 2010 6:25 pm
i think i have set everything up ok but i have one major problem. i have z-subsonic on my iphone and when im in my house i can play all my music from my pc onto my iphone, but as soon as i leave my house i loose connection and can not play anything! someone please help as this has the potential to be a fantastic app! thanks in advance.
paul1977
Postby mjones73 » Sun Apr 25, 2010 7:09 pm
I take it you entered the local IP of where ever your server is running and not your Internet IP. You need to use your external Internet IP and have the port forward from your router to the machine the Subsonic app is running on.
It's detailed here - http://forum.subsonic.org/forum/viewtopic.php?t=1403
mjones73
help
Postby paul1977 » Sun Apr 25, 2010 8:09 pm
thanks for your help but im still confused. ive found my external ip address. where do i enter this info and where do i find my port number? sorry im rubbish at anything like this.
paul1977
Postby mjones73 » Sun Apr 25, 2010 8:54 pm
I'm not familiar with the iphone app but you'd use that external IP as your server address on your iphone.
Unless you've changed anything, subsonic should be running on port 80. You need to set up port forwarding on your router to take requests on port 80 and to forward them to the IP address of the machine subsonic is on. That's assuming you have a router.
What that does is allow you to connect home over the Internet and the port forwarding allows you to get to your subsonic server.
If you need more help give us your router make and model.
mjones73
Help
Postby paul1977 » Sun Apr 25, 2010 10:09 pm
My router is a thomson TG585V7. Thankyou for your continued help
paul1977
Re: please help me
Postby sola » Wed Apr 28, 2010 7:50 pm
paul1977 wrote:i think i have set everything up ok but i have one major problem. i have z-subsonic on my iphone and when im in my house i can play all my music from my pc onto my iphone, but as soon as i leave my house i loose connection and can not play anything! someone please help as this has the potential to be a fantastic app! thanks in advance.
Load up the subsonic server in your browser.
Navigate to Settings --> Network.
Check "Automatically configure your router to allow incoming connections to Subsonic (UPnP port forwarding)."
Check "Access your server over the Internet using an easy-to-remember address."
Register a username at the subsonic.org address.
Use this new URL with Z-Subsonic.
Alternatively, you can register a free Dynamic DNS address at www.no-ip.com. Install the client software on your Subsonic server computer so it will always update your IP address with the Dynamic DNS service.
Use the new free No-IP address with Z-Subsonic. If you need further help, please email me at helpdesk (at) z-subsonic.com
Olusola (Sola) Abiodun
http://Z-Subsonic.com
sola
Users browsing this forum: No registered users and 44 guests
