Problem with AD and Subsonic 4.0.1 (build 1529)
Postby aleyali » Sat May 15, 2010 4:11 pm
Hi Support Team!
I have an Active Directory on windows server 2003 for my company to use to log in across the domain systems. I am trying to implement Subsonic with LDAP support.
And I deploy latest version of Subsonic 4.0.1 (build 1529) on one of domain computer with windows 2003 and IIS 6.0.
The problem I am running into is that I have specified all the values in Settinga-Advanced, but any domain user still unable to log in.
kindly help me in this regards.
My log is:
[2010-05-15 21:09:38,445] INFO SubsonicLdapBindAuthenticator - Failed to authenticate user 'ali' in LDAP.
org.acegisecurity.BadCredentialsException: Bad credentials; nested exception is javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 525, vece ]
   at org.acegisecurity.ldap.DefaultInitialDirContextFactory.connect(DefaultInitialDirContextFactory.java:184)
   at org.acegisecurity.ldap.DefaultInitialDirContextFactory.newInitialDirContext(DefaultInitialDirContextFactory.java:261)
   at org.acegisecurity.ldap.DefaultInitialDirContextFactory.newInitialDirContext(DefaultInitialDirContextFactory.java:241)
   at org.acegisecurity.ldap.LdapTemplate.execute(LdapTemplate.java:123)
   at org.acegisecurity.ldap.LdapTemplate.searchForSingleEntry(LdapTemplate.java:246)
   at org.acegisecurity.ldap.search.FilterBasedLdapUserSearch.searchForUser(FilterBasedLdapUserSearch.java:119)
   at org.acegisecurity.providers.ldap.authenticator.BindAuthenticator.authenticate(BindAuthenticator.java:71)
   at net.sourceforge.subsonic.ldap.SubsonicLdapBindAuthenticator.authenticate(SubsonicLdapBindAuthenticator.java:72)
   at org.acegisecurity.providers.ldap.LdapAuthenticationProvider.retrieveUser(LdapAuthenticationProvider.java:233)
   at org.acegisecurity.providers.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:119)
   at org.acegisecurity.providers.ProviderManager.doAuthentication(ProviderManager.java:195)
   at org.acegisecurity.AbstractAuthenticationManager.authenticate(AbstractAuthenticationManager.java:45)
   at org.acegisecurity.ui.webapp.AuthenticationProcessingFilter.attemptAuthentication(AuthenticationProcessingFilter.java:71)
   at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:252)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
Caused by: javax.naming.AuthenticationException: [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 525, vece ]
   at com.sun.jndi.ldap.LdapCtx.mapErrorCode(Unknown Source)
   at com.sun.jndi.ldap.LdapCtx.processReturnCode(Unknown Source)
   at com.sun.jndi.ldap.LdapCtx.connect(Unknown Source)
   at com.sun.jndi.ldap.LdapCtx.<init>(Unknown Source)
   at com.sun.jndi.ldap.LdapCtxFactory.getUsingURL(Unknown Source)
   at com.sun.jndi.ldap.LdapCtxFactory.getUsingURLs(Unknown Source)
   at com.sun.jndi.ldap.LdapCtxFactory.getLdapCtxInstance(Unknown Source)
   at com.sun.jndi.ldap.LdapCtxFactory.getInitialContext(Unknown Source)
   at javax.naming.spi.NamingManager.getInitialContext(Unknown Source)
   at javax.naming.InitialContext.getDefaultInitCtx(Unknown Source)
   at javax.naming.InitialContext.init(Unknown Source)
   at javax.naming.InitialContext.<init>(Unknown Source)
   at javax.naming.directory.InitialDirContext.<init>(Unknown Source)
   at org.acegisecurity.ldap.DefaultInitialDirContextFactory.connect(DefaultInitialDirContextFactory.java:180)
   ... 41 more
Aleyali.
aleyali
Postby sliver4321 » Mon May 17, 2010 1:50 pm
sliver4321
Postby aleyali » Wed Jun 02, 2010 9:54 pm
Why need extra programming?
aleyali
Postby linuxman » Thu Jun 03, 2010 8:01 am
No programming skip down and read the discussion about ldap logging into active directory and you'll find how to fix your problems.
linuxman
Hi Mate
Postby primary » Mon Jun 07, 2010 9:41 am
I had the same problem but I found that the LDAP adress I was using was wrong. Have a look at my help tread and it might help you out.
http://forum.subsonic.org/forum/viewtopic.php?t=3352
Also under advanced settings, you need to provide a user and password for LDAP authentication, NOTE on that is that you must use DOMAIN\USER for it to work. Same with the program I used to find my correct LDAP path on AD.
primary
