Access or dump the database from outside of subsonic?
Postby Gonzo » Thu Jun 10, 2010 6:44 am
I would like to be able to access the database from outside subsonic, a dump of the data would be fine. Does anyone know a handy tool to dump a HSQLDB?
Thanks in advance
Gonzo
Postby oeh » Thu Jun 10, 2010 12:07 pm
Have a look at the sqlite home page.
http://www.sqlite.org/
on linux you'll find the sqlite database file in:
/var/subsonic/db
Regards
OEH ;-}
oeh
Postby Gonzo » Thu Jun 10, 2010 2:58 pm
are your sure, theese are sqlite files?
judging the files, I would say, it is HSQLDB?
Gonzo
Postby oeh » Thu Jun 10, 2010 4:21 pm
Sorry :oops:
Should have stuck to my first hunch to day,
and stayed in bed an just ticked the whole day of in the calendar :wink:
But you are perfectly right it is HSQLDB
Regards
OEH ;-}
oeh
Postby jonathanroz » Thu Jun 10, 2010 5:03 pm
You can access the subsonic db by going to http://yourserver/db.view?
You can do most SQL commands from there. You can copy and paste the results of the Select * from TABLENAME into Excel or something if you really need to do work outside of subsonic.
There are a few hsqldb shareware apps out there with a 30 day free trial, but once you know the table names there is nothing you can't just do in the db.vew
Below are the tables I am aware of:
custom_avatar
internat_radio
music_file_info
Music_folder
Player
Player_transcoding
podcast_channel
podcast_episode
role
system_avatar
transcoding
user
user_rating
user_role
user_settings
version
jonathanroz
Postby Gonzo » Thu Jun 10, 2010 6:16 pm
jonathanroz wrote:You can access the subsonic db by going to http://yourserver/db.view?
Great! Just perfekt for me, just what I needed (needed to get some comments (for directories) from a backup...
Thanks a lot :D
Gonzo
Postby oeh » Thu Jun 10, 2010 7:42 pm
Great, didn't know that.
Maybe you could write something about that in the wiki?
:roll:
Regards
OEH ;-}
oeh
Postby mgrant » Mon Jun 14, 2010 2:57 pm
oeh wrote:Maybe you could write something about that in the wiki?
:roll:
https://sourceforge.net/apps/mediawiki/ ... e=Database
-mg
mgrant
