No music folders found. Please change the settings.
Postby G4TS » Fri Jun 11, 2010 2:51 pm
Sorry for my english but i'm french.
So when i open subsonic, it say to me : No music folders found. Please change the settings.
But when i go into settings, i've no option for music folder, only personnal, password and players.
I have read the documentation and i'dont see the same page of settings like this : Image where are the option for music folder.
please help me.
Thx
G4TS
Postby Gonzo » Fri Jun 11, 2010 3:16 pm
It sounds, like you don't use an account with administrative rights. Try the original admin account and change the settings there or use the admin-Account to edit your user and check "User is Administrator".
Gonzo
Postby G4TS » Fri Jun 11, 2010 3:50 pm
Thanks a lot, it was a problem of admin rigth.
Now, I've got the option music folder but when i set the folder like "e:\Mes documents\Ma musique\Mp3" where are my musics, it don't show it and continu to show me "no music folders found, please change the settings".
I don't understand!! It's the good folder I set .
G4TS
Postby kermit22 » Fri Jun 11, 2010 5:01 pm
try going into Settings>Search and then click "Update Search Index Now" and see if any of your music gets added.
kermit22
Postby baskie » Fri Jun 11, 2010 5:13 pm
I was reading in another post that someone found out that server side of subsonic didnt like folders starting with a period "." I notice that you have a period in your folder names, If you havent fixed your problem yet you might want to give that a try.
baskie
Postby G4TS » Fri Jun 11, 2010 5:28 pm
Thanks all for help!
Subsonic seems to not agree folders with "space" in theirs names ( "e:\Mes document" for example).
I've try to copy some album's folder in "e:\music" and it found it very well. It's sad to have to change my music's directory because it's always used by another applications.
G4TS
Postby G4TS » Fri Jun 11, 2010 7:24 pm
Now, it works on my PC!! I try it on Android phone (samsung galaxy spica, 2.1).It works nice in wifi (i've only try from my house) but a network error occured appears in H/3g/E and it couldn' connect and play!
Info: I'm a Free users in france, maybe the settings for the router is special? I have open the port 80 on my webrouter but the network error is always there.
G4TS
Postby boulate » Fri Jun 11, 2010 11:53 pm
Tiens, un p'tit Français ;)
My answer will be in English :
You have to open the port number 4040, not the 80.
Subsonic isn't installed by default on the default HTTP port.
I have the same probleme with my directory.
If I give subsonic a folder containing music in "Music folders" section, it's ok.
But if I give a folder containing other folders : nothing is found.
Example :
If music folder is : "/home/boulate/music/eminem/recovery" : it works.
If music folder is : "/home/boulate/music" : nos music folder found
The only way I found was to put each new album music folder in "Music folders" option.
Recursive problem ?
boulate
Postby G4TS » Sat Jun 12, 2010 12:47 pm
It works fine now in wifi and 3g.
I have just open the port 80 and it works.
Now i saw the network function is limited in time. :cry:
Thanks all !! :D
G4TS
