Cannot connect to site
Postby Darksthour » Fri Aug 13, 2010 7:47 pm
Every time i try to change my network settings to access the server over the internet i get an error saying the site is registered, but it could not connect to it (ConnectTimerException). I have set my IP settings to a static address and the port says its successfully forwarding. I even turned off my firewall to see if that was the problem... it wasn't. I don't know what to do or what the error message means. Any help would be greatly appreciated. I would love to use this app on my phone.
Darksthour
Postby kermit22 » Fri Aug 13, 2010 8:54 pm
Are you able to connect to subsonic from inside your local network?
-My Subsonic Server-
OS: Windows Server 2016
Processor: Intel Xeon E5630
Memory: 8GB
2,098 artists
4,266 albums
39,450 songs
2,606 hours
kermit22
Postby Darksthour » Sat Aug 14, 2010 12:05 am
Yea, I. Can get music to play but when I try to make that site to play it on my droid it says it can't connect. I'm running it off my wireless. I have a Linksys router
Darksthour
Postby Kirk » Sun Aug 15, 2010 8:08 pm
Try checking if your Subsonic port is forwarded correctly. Go to You Get Signal's port forward tester and change the port from 80 to your Subsonic port. (4040 usually). If the port isn't correctly forwarded, the UPnP is most likely not working and you will need to forward the port manually.
Also, if you use Subsonic for more than 30(?) days without a license, the APIs for mobile streaming apps will no longer work.
Cheers,
Kirk
Kirk
