Win7+Android Setup
Win7+Android Setup
Postby Randyd718 » Thu Aug 19, 2010 10:25 pm
When you rename your server to http://yourname.subsonic.org, how do you set the login for it? I've navigated to it on my browser and tried signing in on the Android app and it doesn't allow me access when I use the same login from http://localhost
Randyd718
Postby Kirk » Fri Aug 20, 2010 8:45 pm
You aren't renaming the server, you're simply setting up an alias for it. Changing your server's DNS will not affect the user and password database. Are you certain you're using the correct credentials and Subsonic URL...?
Cheers,
Kirk
Kirk
