4.1.beta1 is out. APE and MPC Trancoding still faulty
Postby hopo » Tue Aug 24, 2010 2:44 pm
New version is out but with same problems Transcoding does not work! Songs plays about one second.
It hasn't been working since 4.0.beta1.
Windows 7 64bit / Firefox 3.6.8
[2010-08-24 17:32:46,248] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [F:\Z_Class\Classic1\Andreas Scholl_Arias for Senesino_ape+cue+covers\Scholl\Scholl.ape] [-f] [wav] [-]
[2010-08-24 17:32:46,399] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\lame] [-b] [256] [-] [-]
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) FFmpeg version SVN-r21231-Sherpya, Copyright (c) 2000-2010 Fabrice Bellard, et al.
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) built on Jan 16 2010 05:42:31 with gcc 4.2.5 20080919 (prerelease) [Sherpya]
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavutil 50. 7. 0 / 50. 7. 0
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavcodec 52.47. 0 / 52.47. 0
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavformat 52.47. 0 / 52.47. 0
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavfilter 1.15. 0 / 1.15. 0
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libswscale 0. 8. 0 / 0. 8. 0
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [ape @ 0186cea0]Estimating duration from bitrate, this may be inaccurate
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Input #0, ape, from 'F:\Z_Class\Classic1\Andreas Scholl_Arias for Senesino_ape+cue+covers\Scholl\Scholl.ape':
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Duration: 01:05:30.96, start: 0.000000, bitrate: N/A
[2010-08-24 17:32:47,068] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0: Audio: ape, 44100 Hz, stereo, s16
[2010-08-24 17:32:47,071] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Output #0, wav, to 'pipe:':
[2010-08-24 17:32:47,071] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[2010-08-24 17:32:47,071] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream mapping:
[2010-08-24 17:32:47,071] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0 -> #0.0
[2010-08-24 17:32:47,071] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Press [q] to stop encoding
[2010-08-24 17:32:47,071] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) size= 2880kB time=16.72 bitrate=1411.2kbits/s
[2010-08-24 17:32:47,621] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) size= 5760kB time=33.44 bitrate=1411.2kbits/s
:evil:
hopo
Postby hopo » Wed Aug 25, 2010 12:50 pm
With Linux (Mint 9) transcoding is broken too. Plays only one second.
[2010-08-25 15:44:20,546] INFO PlaylistInputStream - admin listening to "APE/cd1.ape"
[2010-08-25 15:44:20,549] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-i] [/home/hopo/Music/Musat/APE/cd1.ape] [-f] [wav] [-]
[2010-08-25 15:44:20,558] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/lame] [-b] [128] [-] [-]
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1, Copyright (c) 2000-2009 Fabrice Bellard, et al.
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) configuration: --extra-version=4:0.5.1-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavutil 49.15. 0 / 49.15. 0
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcodec 52.20. 1 / 52.20. 1
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavformat 52.31. 0 / 52.31. 0
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavdevice 52. 1. 0 / 52. 1. 0
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavfilter 0. 4. 0 / 0. 4. 0
[2010-08-25 15:44:20,575] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libswscale 0. 7. 1 / 0. 7. 1
[2010-08-25 15:44:20,576] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2010-08-25 15:44:20,576] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) built on Mar 4 2010 12:35:30, gcc: 4.4.3
[2010-08-25 15:44:20,577] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, ape, from '/home/hopo/Music/Musat/APE/cd1.ape':
[2010-08-25 15:44:20,578] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Duration: 01:13:07.58, start: 0.000000, bitrate: N/A
[2010-08-25 15:44:20,578] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: ape, 44100 Hz, stereo, s16
[2010-08-25 15:44:20,578] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[2010-08-25 15:44:20,578] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, s16, 1411 kb/s
[2010-08-25 15:44:20,579] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2010-08-25 15:44:20,585] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[2010-08-25 15:44:20,585] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop encoding
[2010-08-25 15:44:20,591] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:20,603] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:21,241] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:21,256] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size= 1440kB time=8.36 bitrate=1411.2kbits/s
[2010-08-25 15:44:21,260] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:21,871] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:21,892] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size= 2592kB time=15.05 bitrate=1411.2kbits/s
[2010-08-25 15:44:21,896] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:22,302] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:22,380] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:22,394] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) size= 3456kB time=20.06 bitrate=1411.2kbits/s
[2010-08-25 15:44:22,399] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:22,410] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:22,826] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[2010-08-25 15:44:22,903] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) av_interleaved_write_frame(): Error while opening file
hopo
Postby hopo » Mon Sep 06, 2010 4:55 pm
Can someone play APE or MPC files with this beta version?
I would like to know what is wrong in transcoding pack with all these new versions?
hopo
Postby delcypher » Mon Sep 06, 2010 7:23 pm
Have you guys tried the ugly fix I suggested in this thread? (Transcoding then streaming of MPC or APE files not working in firefox).
http://forum.subsonic.org/forum/viewtopic.php?t=2939&start=12
Sorry I don't have time to test the new beta at the moment.
delcypher
Postby hopo » Wed Sep 29, 2010 2:35 pm
Yes i did try ugly fix but that's not very good solution either.
Hope this bug can be fixed. Really frustrating to use Subsonic.
hopo
Postby oeh » Mon Feb 07, 2011 5:40 pm
From http://ubuntuforums.org/showthread.php?t=121199 i found this.
Works on Ubuntu 10.10 64 powerpc
In terminal run:
$ sudo updatedb
$ locate libmp3lame.so
should reveal:
$ /usr/lib/libmp3lame.so.0
Stop Subsonic:
$ sudo service subsonic stop
then in terminal run:
$ sudo ln -s /usr/lib/libmp3lame.so.0 /usr/lib/libmp3lame.so
then start Subsonic:
$ sudo service subsonic start
It should now work as a charm.
Regards
OEH ;-}
oeh
