Subsonic won't work for me. Please help
Postby pjunk7 » Sat Aug 28, 2010 1:40 pm
Hi
I installed the subsonic server on my laptop (windows), but whenever i click on server address in the control panel (http://localhost/), all i get in the browser is a window that says "website not found/cannot open this address". i.e. web interface won't load.
It is my first time trying to use this software.
using port number 80 (default). i have tried different port numbers and none seem to work.
please help
thanks
pjunk7
Postby Kirk » Sat Aug 28, 2010 8:04 pm
Purely out of curiosity, what version of Windows?
It's entirely possible that your hosts file is not resolving localhost correctly. Have you tried navigating your browser to http://127.0.0.1/ and see if that works? Have you tried navigating to the computer's LAN IP from another system on your network?
Cheers,
Kirk
Kirk
Postby jakobedlam » Thu Sep 02, 2010 3:58 am
I'm having this exact same problem on a WinXP pro machine. I cannot connect to localhost, either by that name or 127.0.0.1. I cannot get the subsonic page to display using another computer on my network (using the IP address, with or without the :8080 added). Subsonic is set to default settings, so it should be port 80.
I have gone to my router and forwarded traffic to port 80 to my computer.
Still cannot get to the subsonic interface. Is there a windows setting I'm missing?
jakobedlam
Postby stueyboy » Thu Sep 02, 2010 8:07 am
Is the windows firewall blocking traffic from any applications? That is sometimes an issue and you don't always get a warning message
stueyboy
Postby jakobedlam » Thu Sep 02, 2010 10:53 pm
windows firewall is turned off. Could it be doing this while off?
jakobedlam
Postby cliston » Sat Sep 04, 2010 3:08 pm
I can't get this to work either. My firewall is off and I've reinstalled it a few times. I am running windows 7
I get this error every time from the local host
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
cliston
Postby johnkdavis » Mon Sep 06, 2010 11:43 pm
I'm a new user experiencing the same problem. I have opened the port number on my router hoping that would work. It did not.
Subsonic is the only solution I found for listening to unsupported audio formats on my Nexus One. Please assist me to get this setup on my PC (running under Windows Ultimate).
johnkdavis
