last.fm scrobbling stopped working
Postby BestMuted » Thu Sep 09, 2010 4:19 pm
I discovered subsonic a few weeks ago, and I love it. I decided to start using last.fm again, because it appears that music will get scrobbled when I play it from my home PC, my work PC and my iPhone. This is awesome.
But, it appears that it stopped working. I installed the latest beta version, made sure to re-enter my credentials, but the music is not being logged on last.fm. Are there any logs I can look at, or is there a debug mode?
BestMuted
Postby Peachcake » Sun Sep 19, 2010 7:50 pm
I noticed that if I have the official Last.fm application installed on my computer and open, some media player that supports its scrobbling (WMP, Winamp, iTunes, etc.) and if that is running in the tray and I forget to close it and then try to play subsonic.... it won't scrobble. Make sure you don't have the Last.fm service/app running anywhere else then it should work. That was my problem.
Peachcake
Postby BestMuted » Tue Sep 21, 2010 5:52 pm
Thanks, but i don't have any other scrobbling apps.
BestMuted
Postby bormuff » Tue Sep 21, 2010 7:59 pm
You can look in the subsonic.log
Try playing a song, then click on 'About' in the web interface and scroll to the bottom of the main frame to see what gets recorded there about Last.fm
Alternatively you could grep for ' AudioScrobblerService' in /var/subsonic/subsonic.log or wherever your log is stored (which should be stated at the bottom of the 'About' page.
bormuff
Postby BestMuted » Thu Sep 23, 2010 3:22 pm
I see nothing in the log file about scrobbling.
[2010-09-23 11:15:16,274] INFO DaoHelper - Checking database schema.
[2010-09-23 11:15:16,594] INFO DaoHelper - Done checking database schema.
[2010-09-23 11:15:16,755] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Fri Sep 24 03:00:00 EDT 2010
[2010-09-23 11:15:16,771] DEBUG NetworkService - Starting PortForwardingTask
[2010-09-23 11:15:16,771] DEBUG NetworkService - Starting URLRedirectionTask
[2010-09-23 11:15:16,817] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Sep 23 11:20:16 EDT 2010
[2010-09-23 11:15:17,301] DEBUG NetworkService - Completed URLRedirectionTask
[2010-09-23 11:15:19,403] INFO PlaylistInputStream - admin listening to "Love At First Sting\02 - Rock you Like a Hurricane.mp3"
[2010-09-23 11:15:19,808] WARN NetworkService - Failed to find UPnP router using WeUPnP library.
java.net.SocketException: Unrecognized Windows Sockets error: 0: Cannot bind
   at java.net.PlainDatagramSocketImpl.bind0(Native Method)
   at java.net.PlainDatagramSocketImpl.bind(Unknown Source)
   at java.net.DatagramSocket.bind(Unknown Source)
   at java.net.DatagramSocket.<init>(Unknown Source)
   at org.wetorrent.upnp.GatewayDiscover.discover(GatewayDiscover.java:95)
   at net.sourceforge.subsonic.domain.WeUPnPRouter.findRouter(WeUPnPRouter.java:39)
   at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.findRouter(NetworkService.java:185)
   at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:132)
   at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:299)
   at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
   at java.util.concurrent.FutureTask$Sync.innerRunAndReset(Unknown Source)
   at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(Unknown Source)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(Unknown Source)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
[2010-09-23 11:15:23,761] INFO VersionService - Resolved local Subsonic version to: 4.1
[2010-09-23 11:15:23,933] INFO VersionService - Resolved latest Subsonic final version to: 4.1
[2010-09-23 11:15:23,933] INFO VersionService - Resolved latest Subsonic beta version to: 4.1.beta1
[2010-09-23 11:15:35,696] INFO PlaylistInputStream - admin listening to "Love At First Sting\01 - Bad Boys Running Wild.mp3"
[2010-09-23 11:15:40,750] INFO StreamController - Got range: Range[1695744,9223372036854775807]
[2010-09-23 11:15:40,756] INFO PlaylistInputStream - admin listening to "Love At First Sting\02 - Rock you Like a Hurricane.mp3"
[2010-09-23 11:17:27,927] INFO NetworkService - Successfully forwarding port 8090.
[2010-09-23 11:17:27,927] DEBUG NetworkService - Completed PortForwardingTask
[2010-09-23 11:18:28,604] INFO PlaylistInputStream - admin listening to "Love At First Sting\03 - I'm Leaving you.mp3"
[2010-09-23 11:18:42,057] INFO PlaylistInputStream - admin listening to "Love At First Sting\04 - Coming Home.mp3"
[2010-09-23 11:20:16,842] INFO PodcastService - Starting scheduled Podcast refresh.
[2010-09-23 11:20:16,842] INFO PodcastService - Completed scheduled Podcast refresh.
[2010-09-23 11:20:41,218] INFO StreamController - Got range: Range[2693384,9223372036854775807]
[2010-09-23 11:20:41,224] INFO PlaylistInputStream - admin listening to "Love At First Sting\01 - Bad Boys Running Wild.mp3"
[2010-09-23 11:20:47,231] INFO PlaylistInputStream - admin listening to "Love At First Sting\02 - Rock you Like a Hurricane.mp3"
[2010-09-23 11:20:47,982] INFO StreamController - Got range: Range[4819816,9223372036854775807]
[2010-09-23 11:20:47,986] INFO PlaylistInputStream - admin listening to "Love At First Sting\03 - I'm Leaving you.mp3"
[2010-09-23 11:20:48,473] INFO PlaylistInputStream - admin listening to "Love At First Sting\04 - Coming Home.mp3"
[2010-09-23 11:20:53,103] INFO PlaylistInputStream - admin listening to "Love At First Sting\05 - The Same Thrill.mp3"
BestMuted
Postby BestMuted » Fri Sep 24, 2010 10:45 pm
Ok, I answered my own question. I was logging in with admin, who didn't have last.fm set up. As soon as I logged in as a different user, it worked.
BestMuted
Postby bormuff » Sat Sep 25, 2010 8:21 am
I was going to ask if that might be the case :)
bormuff
