Version 4.1 Stops Working
Postby nheimler » Sat Sep 11, 2010 1:58 pm
Hello. I posted something in regards to 4.1 beta 1 stops working after a few days and heard no response. Well I've upgraded to the "stable" release of 4.1 and the issue still happens. In fact, I upgraded it last night and it worked until this morning. I have to reboot the machine in order to get this working again. Same problem as the beta 1 had, so something is still buggy about this. The log files report nothing out of the ordinary that usually displays after a reboot and what not. Not sure what other info I can provide. To see the specs of the machine see the link below. And as I noted there 4.0.1 has been "stable" for me as I had no issues until I upgraded to 4.1 beta and now 4.1. I have not tried a fresh install of 4.1, but I was hoping to avoid that as I didn't want to loose all the logins I had setup without resetting up everything.
http://forum.subsonic.org/forum/viewtopic.php?t=4155
Thanks for whomever can help!
nheimler
Postby nheimler » Mon Sep 13, 2010 3:12 am
Am I posting in the right area? Are there not enough people using this to notice any issues? Just trying to find answers and some help in resolving this. Btw is there another area I should be posting if I'm a registered user? Thanks!
nheimler
Postby ccandreva » Mon Sep 13, 2010 3:30 am
Right area, you may just be the only one seeing this. Mine has not had this problem.
ccandreva
Postby mjthfx » Wed Sep 15, 2010 1:38 pm
Hi I just upgraded my ubuntu subsonic to 4.1 and even though the subsonic web interface opens and I can browse my collection, i can no longer add songs to my playlists, therefore 4.1 is not working for me.
FIXED:
Sorry folks... just had to reinstall Java... first line in the instructions :oops:
sudo apt-get install openjdk-6-jre
Then restart Subsonic
sudo service subsonic restart
mjthfx
Postby ccandreva » Wed Sep 15, 2010 1:44 pm
Saved playlists, or any playlist at all as in you can't play anything ?
If it's saved playlists, see what user subsonic is running as:
ps auxww | grep subsonic
and make sure that user has read/write access to your playlist directory.
ccandreva
Postby mjthfx » Wed Sep 15, 2010 1:46 pm
Thanks for the quick reply ccandreva
Got it going... i had to reinstall Java :oops:
mjthfx
Postby danielr » Wed Sep 15, 2010 9:58 pm
I am afraid something similar is happening to me. I am on a Mac.
I had been running 4.0.1 fine for several months. Last night I updated. At first I noticed that the memory was defaulted back to 100m and I fixed that. This morning I could not connect from my iPhone. I restarted the server. Z-Subsonic can connect to the server and see my tracks but when I hit play nothing happens. Artwork apears.
iSub can't even get to the server - I am getting a timeout error. There is nothing indicating a problem in the logs.
Anyone have any advice. Thanks
danielr
Postby danielr » Thu Sep 16, 2010 10:55 am
Just an update. I reinstalled 4.0.1 on my Mac and everything returned back to normal and I was able to listen my playlists on my way to work this morning.
So my guess is 4.1 is the issue or iSub and Z-Subsonic for the iPhone need to be updated for 4.1.
I have a Mac Mini running Snow Leopard 10.6.4 with 4GB of ram and an iPhone 4 on version 4.0.
danielr
Postby nheimler » Fri Oct 01, 2010 3:26 am
Yeah there's something up with 4.1. A colleague of mine is also having a similar issue I am with it locking up after a couple days. Again rebooting fixes the issue for a little while then bamb. 4.0.1 doesn't have this issue. We've both upped the memory for java and it seems to fix the issue for a bit. Something fishy...not sure how to troubleshoot/fix. Nothing in the logs show anything. Nothing with our networks being an issue. Both of us are techs, so we've looking into that being an issue. Plus, 4.0.1 runs stable ever since we installed it when it came out.
nheimler
Postby YourRegrets » Sun Oct 03, 2010 10:54 pm
nheimler wrote:Yeah there's something up with 4.1. A colleague of mine is also having a similar issue I am with it locking up after a couple days. Again rebooting fixes the issue for a little while then bamb. 4.0.1 doesn't have this issue. We've both upped the memory for java and it seems to fix the issue for a bit. Something fishy...not sure how to troubleshoot/fix. Nothing in the logs show anything. Nothing with our networks being an issue. Both of us are techs, so we've looking into that being an issue. Plus, 4.0.1 runs stable ever since we installed it when it came out.
im having the same problems, im not sure if thats the issue with yours crashing, but look into your search index and see how often it does the search, or force a search and if that crashes the system then we have the same problem. mines crash everytime it does a search
YourRegrets
same here
Postby josephl836 » Tue Dec 14, 2010 7:43 pm
Can't connect anything for a reason, but same thing. Randomly quits working. Can't restart from Subsonic control panel. Need to reboot Windows, then fine. Can go days or hours at a time before quitting. Service shows as running in task manager, but unable to stop it there, 'access denied'
josephl836
Re: same here
Postby alphawave7 » Tue Dec 14, 2010 8:10 pm
josephl836 wrote:Can't connect anything for a reason, but same thing. Randomly quits working. Can't restart from Subsonic control panel. Need to reboot Windows, then fine. Can go days or hours at a time before quitting. Service shows as running in task manager, but unable to stop it there, 'access denied'
Anything in Windows Events log, or SS log?
Postby GJ51 » Tue Dec 14, 2010 9:13 pm
Open services.msc right click on the Subsonic service, select Properties, uncheck the box that says "Alow service to interact with desktop" then click OK.
