Android App Error
Android App Error
Postby catoxpress » Wed Sep 29, 2010 2:21 am
I can connect to the site and browse just fine. Every time I try to "Play" a song, I get the following error:
Error Playing " song "
Prepare failed.: status=0x1
(IOException)
I'm using an Droid X with the latest version 1.7.1 of Subsonic Streaming App
Anybody got any ideas?
catoxpress
I have the exact same issue.
Postby lailoken » Mon Oct 04, 2010 6:54 pm
Me too (same exact error). I have the latest 1.7.1 and a Droid X (running stock Froyo 2.2).
It used to work for me on 2.1, not sure which Subsonic version I had back then.
But the music seems to browse and download just fine, just not play.
After rebooting my device it seems to go away for a while, but returns on occasion.
I thought it may have something to do with my local WiFi connection, but the problem also occurs on pre-cached songs... so I'm not sure about this.
Any other ideas? anyone?
lailoken
Postby Kirk » Mon Oct 04, 2010 10:09 pm
This error message was recently mentioned on this forum thread as well. Are you trying to play MP3 or M4A? (or some other format?)
Cheers,
Kirk
Kirk
Postby sn0skier » Thu Oct 14, 2010 10:09 pm
It happens to me while playing mp3. In case it matters it isn't being encoded first or anything.
sn0skier
Postby sn0skier » Thu Oct 14, 2010 10:11 pm
Also it doesn't happen that often, and when it does I just have to wait a second and then press play again and it works.
sn0skier
Postby sn0skier » Tue Oct 19, 2010 3:27 pm
Which doesn't mean that I want you to ignore this thread. I think that the other problems I'm having with Subsonic might be related. Could the cause of this be a slow SD card?
sn0skier
Postby sn0skier » Wed Oct 20, 2010 6:30 am
I bet the solution for my other problems will work for this too
Defragment SD card.
sn0skier
Users browsing this forum: No registered users and 58 guests
