Unable to access file referenced in playlist
Postby oneiris » Fri Oct 01, 2010 3:06 pm
I'm having problems loading files with spaces in from playlists. I've created a test playlist with the following entry:
"/sound/music/Consensus - Eiskalt.mp3"
And I get the following error in the subsonic log:
java.lang.SecurityException: Access denied to file "/sound/music/Consensus - Eiskalt.mp3"
If I try to escape the spaces with \ I get the same problem. Is there any way to escape spaces in filenames within playlists that Subsonic will accept?
oneiris
Postby bormuff » Fri Oct 01, 2010 3:50 pm
Sounds more like a permissions issue with the file in question, rather than something to do with the whitespace in the filename.
bormuff
Postby oneiris » Fri Oct 01, 2010 3:54 pm
I thought so too, but if I copy that file with the permissions in tact to /sound/music/test.mp3, it works fine from the playlist, so it looks like it's just an issue with whitespace.
oneiris
Postby oneiris » Wed Oct 06, 2010 9:13 am
So nobody else has had issues with filenames containing spaces in a playlist?
oneiris
Postby Kirk » Thu Oct 07, 2010 10:57 pm
oneiris wrote:So nobody else has had issues with filenames containing spaces in a playlist?
Spaces? No. I haven't had any issues like this before.
Have you tried chmodding the file 777? Maybe not a good idea to leave it that way, but it should completely rule out permissions if it still doesn't play back.
Cheers,
Kirk
Kirk
Postby oneiris » Mon Oct 11, 2010 6:26 am
I can't see how it's a permissions issue. If I copy the file to /sound/music/test.mp3 and leave the permissions the same as the original, it plays from the playlist.
oneiris
