Change Port On Linux
Postby spazzmonkeys » Sat Oct 09, 2010 6:03 pm
I recently decided to put subsonic on one of the linux machines I have lying around. Unfortunately I'm not much of a linux guru, and I can't find much in the way of documentation for subsonic for linux. I installed the deb package on ubuntu jaunty. It worked great on port 4040, but I really want it on 80. I changed the port number in /usr/share/subsonic/subsonic.sh and /etc/default/subsonic, but it didn't work. Also, after I tried changing them back to their defaults, subsonic would no longer work on port 4040. Can anyone help, or point me to some documentation?
I also noticed that there's a script in /etc/init.d for the subsonic daemon with start/stop/restart commands. I have a feeling these would really help in diagnosing my port problem. What is the command to run this script? It looks like it's different than what I get when i run "subsonic."
spazzmonkeys
Postby oeh » Sat Oct 09, 2010 8:56 pm
after editing */subsonic.sh you have to restart the subsonic service running on your linux box.
run in terminal:
to restart
user@xxxxx:~$ sudo service subsonic restart
to see what kind of options you have with the subsonic routine type in terminal:
Regards
OEH ;-}
oeh
Postby spazzmonkeys » Mon Oct 11, 2010 4:54 pm
Thank you! That did it. That, and finding out that there seems to be some major error with my router making forwarded ports appear and disappear at random. Time for a new router.
spazzmonkeys
Users browsing this forum: No registered users and 42 guests
