Subsonic Not Working!!
Postby anmills » Sun Oct 10, 2010 6:18 pm
Can I get a clear and concise answer as to why Subsonic is not working for me? And could someone explain the steps to troubleshoot. I'm not a programmer by any stretch of the imagination, nor am I willing to put in huge amounts of time trying to get this to work for me...I'd just like it to work!! I am unable to play any FLAC files in any of the Subsonic programs, Android, Sub Air, or the Subsonic web browser. The only noticeable error I get is from the Android player it says "error playing "song name". Prepare failed.: status=0x1(IOException) there are no errors that I can see in SubAir or the browser Subsonic, the music just doesn't play.
anmills
Postby anmills » Sun Oct 10, 2010 6:32 pm
Forgot to mention that FLAC files play in other music players.
anmills
Postby WildWalker » Mon Oct 11, 2010 9:44 am
Can you play MP3 files? or is it just FLAC that does not play?
Alan.
WildWalker
Postby anmills » Mon Oct 11, 2010 4:44 pm
Hi Alan, I can play MP3s, just the flac won't play
anmills
Postby kermit22 » Mon Oct 11, 2010 8:32 pm
Download the transcoding pack here:
http://subsonic.org/pages/transcoding.jsp
And then make sure that under Settings>Players under the players that you use, SubAir, Android, web etc, make sure that the checkbox by flac>mp3 is checked.
kermit22
Postby anmills » Tue Oct 12, 2010 3:59 am
I'm on a MAC, as far as I can tell, FLAC encoder is installed in the proper directory. All checkmarks are marked, and settings are set properly.
anmills
Postby kermit22 » Tue Oct 12, 2010 12:14 pm
Could you try to play a flac file from the web browser and then post your log file from the about tab?
kermit22
Postby anmills » Wed Oct 13, 2010 12:18 am
[10/12/10 5:16:54 PM PDT] INFO PlaylistInputStream admin listening to "The Grand Bounce/1 The East Wind.flac"
[10/12/10 5:16:54 PM PDT] DEBUG TranscodeInputStream Starting transcoder: [/Library/Application Support/Subsonic/transcode/ffmpeg] [-i] [/Users/sarahmills/Music/Lossless/Gord Downie/The Grand Bounce/1 The East Wind.flac] [-f] [wav] [-]
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) FFmpeg version 0.6, Copyright (c) 2000-2010 the FFmpeg developers
[10/12/10 5:16:54 PM PDT] DEBUG TranscodeInputStream Starting transcoder: [/Library/Application Support/Subsonic/transcode/lame] [-b] [128] [-] [-]
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) built on Sep 27 2010 19:40:29 with gcc 4.2.1 (Apple Inc. build 5646)
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) configuration: --prefix=/opt/local --enable-gpl --enable-postproc --enable-swscale --enable-avfilter --enable-avfilter-lavf --enable-libmp3lame --enable-libvorbis --enable-libtheora --enable-libdirac --enable-libschroedinger --enable-libfaac --enable-libfaad --enable-libxvid --enable-libx264 --enable-libvpx --enable-libspeex --enable-nonfree --mandir=/opt/local/share/man --enable-shared --enable-pthreads --disable-indevs --cc=/usr/bin/gcc-4.2 --arch=x86_64
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavutil 50.15. 1 / 50.15. 1
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavcodec 52.72. 2 / 52.72. 2
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavformat 52.64. 2 / 52.64. 2
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavdevice 52. 2. 0 / 52. 2. 0
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libavfilter 1.19. 0 / 1.19. 0
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libswscale 1.11. 0 / 1.11. 0
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/lame) dyld: Library not loaded: /opt/local/lib/libncurses.5.dylib
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/lame) Referenced from: /Library/Application Support/Subsonic/transcode/lame
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/lame) Reason: no suitable image found. Did find:
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/lame) /opt/local/lib/libncurses.5.dylib: no matching architecture in universal wrapper
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/lame) /usr/lib/libncurses.5.dylib: no matching architecture in universal wrapper
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Input #0, flac, from '/Users/sarahmills/Music/Lossless/Gord Downie/The Grand Bounce/1 The East Wind.flac':
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Metadata:
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) ENCODER : Lavf52.71.0
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Duration: 00:04:28.77, bitrate: 995 kb/s
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0: Audio: flac, 44100 Hz, 2 channels, s16
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Output #0, wav, to 'pipe:':
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) encoder : Lavf52.64.2
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0: Audio: pcm_s16le, 44100 Hz, 2 channels, s16, 1411 kb/s
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream mapping:
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Press [q] to stop encoding
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) Multiple frames in a packet from stream 0
[10/12/10 5:16:54 PM PDT] DEBUG InputStreamReaderThread (/Library/Application Support/Subsonic/transcode/ffmpeg) av_interleaved_write_frame(): Operation not permitted
The complete log is saved in /Library/Application Support/Subsonic/subsonic.log.
Refresh
anmills
Postby anmills » Tue Oct 19, 2010 5:02 am
Anyone help me out?
anmills
Postby Tippi » Tue Oct 19, 2010 7:18 am
What I read from the log is that ffmpeg has problems to convert your flac-file. Do you have this problem with all of your flac-files?
It could be useful to have one of this flac-files to test it manually with ffmpeg. Can you provide one? Perhaps upload it to rapidshare or somewhere else.
Tippi
Postby anmills » Wed Oct 20, 2010 8:27 pm
I am able to convert flac to MP3 in Tanbee AVCHD converter which uses ffmpeg as an encoder without problems. It's all of my FLAC files that cause problems.
anmills
Postby Tippi » Thu Oct 21, 2010 6:25 am
Perhaps Tanbee is using another version of ffmpeg or was compiled with other flags/other versions of libraries (espacially libflaac).
You should try to convert a flac file manually with the ffmpeg provided with subsonic.
Another solution could be to replace the ffmpeg (in subsonic) with the ffmpeg of Tanbee.
Tippi
