ConnectTimeoutException
Postby Ph03Nix » Thu Oct 21, 2010 1:56 am
Hello, i'm having problem with my connection. I donate and receive a code, follow the instructions, but i'm receving this message: Status: xxxxxx.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException). I'm using a router (D-Link 524) and i already configure portforward in the router, but still don't work. I use portforward for other programs and that's ok.... Any ideas?
Thankz.
Ph03Nix
Postby alphawave7 » Thu Oct 21, 2010 3:28 am
Grab the port number you've 'opened' and try www.canyouseeme.org
Does it show the port as open?
Postby Ph03Nix » Thu Oct 21, 2010 3:43 pm
I try again and now it's working fine. Thankz.
Ph03Nix
can some one help me with the same problem?
Postby csharma.uc » Sun Oct 24, 2010 7:01 pm
i'm receving the same message: Status: xxxxxx.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
i tried the website www.canyouseeme.org
Error: I could not see your service on xxx.xxx.xxx.x98 on port (4000)
Reason: Connection timed out
I've opened the port 4000 by going into Netgear router settings page. So whats wrong up here?
csharma.uc
Re: can some one help me with the same problem?
Postby alphawave7 » Sun Oct 24, 2010 8:06 pm
csharma.uc wrote:i'm receving the same message: Status: xxxxxx.subsonic.org is registered, but could not connect to it. (ConnectTimeoutException)
Try rebooting the router..sometimes a pinhole won't 'stick' until a reboot.
Postby csharma.uc » Tue Oct 26, 2010 8:43 am
no success even after rebooting ... doesnt windows 7 64 bit has something to do with it? please help !
CSharma
csharma.uc
Postby GJ51 » Tue Oct 26, 2010 11:58 am
There are a couple things you can try to pipoint where the problem is.
Identify your IP address assigned to your router from your ISP. Once you know the external IP address, try connecting to your server at http://xxx.xxx.xxx.xxx:port number to try and access the server.
If that works, try servername.subsonic.org:port number.
Make sure the port # is the same throughout the connection chain.
Postby csharma.uc » Tue Oct 26, 2010 2:51 pm
nice
nothing works for me..i will try subsonic on my laptop.. nothing worked for me so far..
i tried using my ip address of router with port number and firefox doesn't take me anywhere and error page pops up
CSharma
csharma.uc
Postby csharma.uc » Tue Oct 26, 2010 2:58 pm
well there is something new i noticed and when ever i go and try to change the settings in control panel and try to save them i get an error message..
Error: Failed to write to C:\Program Files (x86)\subsonic\subsonic-service.exe.vmoptions. subsonic-service.exe.vmoptions (Access is Denied)
(And this thing has already happened to me one day ago and i had to reinstall if from scratch and it went away..but now it popped up again)
Please HELP !![/img]
CSharma
csharma.uc
Postby GJ51 » Tue Oct 26, 2010 3:23 pm
Haqve you tried a Java uninstall/reinstall?
http://www.java.com/en/download/manual.jsp
If you're using Windows 64 bit, be sure to install both 32 & 64 bit versions.
Postby kermit22 » Tue Oct 26, 2010 4:59 pm
csharma.uc you will need to start the subsonic services with administrator privilidges in order to get rid of your error message "Error: Failed to write to C:\Program Files (x86)\subsonic\subsonic-service.exe.vmoptions. subsonic-service.exe.vmoptions (Access is Denied)"
kermit22
Need HELP !!!
Postby csharma.uc » Tue Oct 26, 2010 9:42 pm
I'm getting frustrated now for real. Well it might be my fault too but i have followed all the steps and what so ever...nothing seems like working for me.. i haven't even used this for one time.. I have followed all the steps so far. Installed new updated for windows7 (64 bit) and windows VISTA (32 bit) and installed JAVA. Port forwarded to 4000 and then tried on 4040.
Does any one have any video of installation? like on youtube or something.. i tried installing subsonic 3-4 times...
Well i really want to use it.. Please help me
Windows 7 (64 bit) PC
Windows Vista (32 bit) laptop
Netgear Wireless G router Model WGR614v9
csharma.uc
