Android Offline Mode
Postby mbern1008 » Sat Oct 30, 2010 3:49 pm
How do you get offline mode to work. I have been using the app for quite some time and have never been able to get it to work. I have roughly 4 gigs of music cached to the sdcard. I can go to offline mode and navigate the saved tracks. When I go to play one it goes to the play screen but gets stuck there. All it says at the bottom is downloading. and it will never play. I can play the songs using the stock music player and winamp with the only problem being that they do not read the tags properly.
mbern1008
Postby MediocreFred » Sat Oct 30, 2010 6:06 pm
I have the same problem in offline mode. I can browse through the downloaded songs and I know the songs are complete because I can see them in the sd card and can transfer them to my PC and they play just fine.
I can also play all the cached songs using my default music player (cubed) on the Evo.
When I select any song to play, it stays at 0:00 and there is an the following error notification:
Error Playing <song-filename>.
Prepare failed.: status=0x1 (IOException)
What am I doing wrong?
MediocreFred
Postby amels802 » Mon Nov 15, 2010 11:00 pm
Bumping this thread as I have always had the same issue... Offline mode working for anyone else or can someone explain it's purpose if it needs to download?
amels802
Postby GJ51 » Tue Nov 16, 2010 2:10 am
Mine has always worked on my EVO 4G. My on glitch is the first track repeat.
Ver. 1.8.2 is the current version.
Postby GJ51 » Tue Nov 16, 2010 2:13 am
Go figure, just tested ofline play and the first track did NOT repeat!!
I guess I'll try it online next.
Postby mbern1008 » Mon Nov 22, 2010 4:23 pm
Just updated to the newest release today and it seems to be working on my Droid X now. Thank you :)
mbern1008
