4.2 Problem
4.2 Problem
Postby rodan1967 » Sun Nov 21, 2010 11:53 pm
I just installed version of Subsonic 4.2 on my win 7 machine. This is what I get when I try to login now.
WEB-INF/ 0 bytes Nov 21, 2010 6:50:51 PM
ad/ 0 bytes Nov 21, 2010 6:50:51 PM
error.jsp 2122 bytes Apr 21, 2010 8:22:10 PM
flash/ 0 bytes Nov 21, 2010 6:50:52 PM
icons/ 8192 bytes Nov 21, 2010 6:50:59 PM
script/ 0 bytes Nov 21, 2010 6:50:51 PM
style/ 0 bytes Nov 21, 2010 6:50:51 PM
xsd/ 0 bytes Nov 21, 2010 6:50:51 PM
Any ideas what is going on?
rodan1967
Postby Exrace » Mon Nov 22, 2010 3:56 am
What version of java are you running?
Exrace
re
Postby pcs800 » Mon Nov 22, 2010 4:27 am
I installed 4.2 and get the folowing.
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
I always update and have been running subsonic for a couple years now. Never had an issue like this.
I am sure it's temporary, but just thought I'd report it.
pcs800
Postby ccandreva » Mon Nov 22, 2010 4:49 am
On my fedora install I had to delete the directory subsonic unpacks the war file too. For me it was /var/subsonic/jetty/1944
It may be diffent for you, but the subsonic_sh.log file will tell you where it is unpacking too.
ccandreva
Postby Exrace » Mon Nov 22, 2010 11:51 am
I upgraded fine on windows 2008 r2 so it might be just a installer bug.
Exrace
re
Postby pcs800 » Mon Nov 22, 2010 1:14 pm
Mine is a windows 2003 server, never had an issue before. Should I uninstall completely and reinstall? Seems like I'd lose the library at that point, and users.
pcs800
re
Postby pcs800 » Mon Nov 22, 2010 8:34 pm
I downloaded and installed the beta over top the newest release and it fixed the issue. I'll wait for the next update.
pcs800
Postby rodan1967 » Tue Nov 23, 2010 12:03 am
Updated my Java did not fix problem. Did clean install did not fix problem. Increased amount of memory Subsonic could use in the system tray config app and problem solved.
rodan1967
Re: re
Postby TommyV » Fri Nov 26, 2010 8:54 pm
pcs800 wrote:I installed 4.2 and get the folowing.
HTTP ERROR: 404
NOT_FOUND
Same problem for me. Worked like a charm prior to upgrading. Now this. :-(
TommyV
Re: re
Postby gtride » Fri Nov 26, 2010 11:14 pm
HTTP ERROR: 404
NOT_FOUND
i had same problem after running the windows installer.
something in the upgrade process is causing the disconnect, so i did a fresh install of 4.2 and its working fine.
gtride
re
Postby pcs800 » Sat Nov 27, 2010 3:27 pm
Did that cause you to lose your users and other settings?
pcs800
re
Postby pcs800 » Mon Nov 29, 2010 7:15 pm
Installed the latest version on a brand new machine which has never had any previous version installed on it and got the same thing.
pcs800
re
Postby pcs800 » Mon Nov 29, 2010 7:28 pm
Uninstalled 4.2 from the new machine, installed the beta of 4.2 and get the same issue. What is going on here?
pcs800
re
Postby pcs800 » Tue Nov 30, 2010 2:07 am
So nobody else is having this issue? It's just me and my three computers I have tested it on?
pcs800
Postby Exrace » Tue Nov 30, 2010 11:31 am
What is in your error log?
Exrace
