Is there a quick way to remove underscores?
Postby Ortusdux » Mon Nov 22, 2010 9:45 am
A large fraction of my library has underscores in place of spaces. They are only present in the folder and file names. They are not in the tags.
http://i.imgur.com/Rjs47.jpg
I can guess at two solutions:
-feature to auto-replace '_' with a space
-the ability to sort the library by artist tags
Ortusdux
Re: Is there a quick way to remove underscores?
Postby mamekedi » Wed Nov 24, 2010 8:40 am
Ortusdux wrote:A large fraction of my library has underscores in place of spaces. They are only present in the folder and file names. They are not in the tags.
Yes there is:
http://www.finebytes.com/mfr/ (best for file renaming)
http://www.softpointer.com/tr.htm
mamekedi
Postby burjast » Wed Nov 24, 2010 10:03 am
Maybe someone knows about file renamer, that doesn't change modified time on files? :) Because I normally list mp3's (at home) by modified date, so I see newly added, and if times are changed, then I loose this ability.
I just know.
burjast
