Subsonic on Linux, Music Files on Windows 7
Postby Argon » Thu Nov 25, 2010 1:55 pm
I can't get it to work!
How can I point Subsonic (installed on Ubuntu 10.04) to search my music files onto a Windows 7 Share.
On the command line I can go to cd /home/computer_name/.gvfs/my_windows_shared_directory If i do this, then i can see al my maps with music.
If I paste above link into Sussonic, it doesn't find any mp3 files. How can I create a working link so that Subsonic know that my music is on a network share?
Argon
Postby Exrace » Thu Nov 25, 2010 2:10 pm
Might be the share is not allowing "everyone" to read.
Subsonic understands a unc path so use the proper UNC path in subsonic like \\mypc\Tunes
Exrace
Postby Argon » Thu Nov 25, 2010 2:55 pm
Everyone can read/write in the folder. I just checked it on the Windows 7 machine...
Argon
Postby seanpkeown » Thu Nov 25, 2010 5:12 pm
Argon wrote:Hello,
Did add everyone under both the security tab and under the advanced sharing>permissions tab?
seanpkeown
Postby Argon » Fri Nov 26, 2010 2:32 pm
seanpkeown wrote:
Argon wrote:Hello,
hello,
Yes, they are both added!
My computername is "Nils-PC" and the music folders sharename is "Muziek"
I Tried in subsonic:
\\nils-pc\Muziek
//nils-pc/Muziek
\\192.168.1.6\Muziek
//192.168.1.6/Muziek
I don't know what to do now :-)
In the terminal, I can see my music folders if I go to "cd /home/xbmc/.gvfs/muziek\ on\ nils-pc
If I do a ls all my music maps show up. I think the share is available if I can do that? :-)
Argon
Postby Argon » Fri Nov 26, 2010 2:51 pm
It works !
I mounted the Windows Share to Linux with this command:
sudo mount -t cifs -o username=my_username,password=my_password //192.168.1.6/Muziek /mnt/win
In subsonic my input for my music folder is now: /mnt/win
Argon
Postby stueyboy » Fri Nov 26, 2010 3:34 pm
you can permanently map this sort of drive in linux if you don't want to have to do this every time. Have a look at this thread and you ought to be able to work it out.
http://ubuntuforums.org/showthread.php?t=288534
stueyboy
Postby ootuoyetahi » Fri Nov 26, 2010 10:07 pm
Mount the windows share to the linux box.
ootuoyetahi
