Android App: Only seeing "first" music folder in M
Postby darkuni » Mon Nov 29, 2010 10:46 pm
I've poked through the forums and online documentation ... so I apologize in advance if I missed something there....
In SubSonic, I have two music folders set up: Folder A and Folder B (let's say).
Folder A is the "bulk" of my music - Folder B is a "temporary" spot I'll throw random crap in that I want remote access to.
In the web application, it's no problem - everything appears as it should ... I have ALL FOLDERS selected and I have access to stuff in Folder A and Folder B. SEARCHING produces results from BOTH folders.
On the Android App, however, Folder A is the only one that appears in the second "Music Library" tab. Folder B doesn't seem to span with the search (in fact, if I search for something in there, I currently get some sort of a server error).
However ...
If I make a PLAYLIST of what's in Folder B - I can access it through the playlists and get to it.
Is this a "known" issue that only the TOP level folder is available on the Android?
Be happy to augment with any further information.
Thank you!
darkuni
Postby darkuni » Mon Nov 29, 2010 10:54 pm
I may have answered my own question - but should at least point out how someone else may have similar issues.
Folder B has loose files in it - not a rigid folder structure like Folder A. In fact, all the files in Folder B sit on the ROOT of the folder.
While they show up in the WEB admin, they do NOT show up in the Media Library on the phone.
Easy enough - I can throw those files into a folder within FOLDER B. Problem solved.
However, I would feel that the Android app should mirror the web interface by allowing those "loose" files to appear at the BOTTOM of the music library tab of the app - OR create a virtual folder called "ROOT" or something similar that would toss those files in there so they can be accessed.
In any event, I'll report the "search" bug separately.
I guess in resolution here:
1) Is this INTENTIONAL? Should "root" files be lost in the Music Library tab?
2) If so, should SEARCH still look for those files and at least offer them up as a search result? It works in the web interface.
Thanks again!
darkuni
Same Problem
Postby alexhaj » Mon Dec 06, 2010 1:15 am
This problem also seems to exist in SubAir.
alexhaj
Postby GJ51 » Mon Dec 06, 2010 4:55 am
