How do I play videos with Subsonic?
Postby hypuk » Tue Dec 28, 2010 6:04 pm
Hi guys
I have a bunch of windows medis video files i want to add to my subsonic server to play them within Subsonic.
How do I go about this?
Any help would be much appreciated
Mark
hypuk
Postby GJ51 » Tue Dec 28, 2010 9:05 pm
The best information I've heard is that video capability is in development for a future release, hopefully the next one. There's a kludge solution in the tutorial section, but it is not reliable. The player fails to initiate consistently.
Let's hope a new release is comming soon.
Postby hypuk » Tue Dec 28, 2010 9:06 pm
Thanks for your reply
Is there anyway of getting the videos to play in a external player? Like Windows Media or VLC?
hypuk
Postby GJ51 » Tue Dec 28, 2010 9:17 pm
That's easy, and it works! Just define an external player with playlist in the settings/players section. When you select the External player for playback it will call the default media player on the desktop calling for the video. I use WMP set to playback all defaults, but VLC works fine too. Be sure to install Klite codecs. Some .avi files don't play properly as they don't pass the play list in the format expected in WMP, but other than that everything I tried worked fine. Let me know if you have questions.
Postby hypuk » Tue Dec 28, 2010 9:27 pm
Hi Gary
Thanks for your help on this.
So I've created a folder with some videos in there, do I have to add it like I did with the music folder? I'm not sure what to do after this
I'm currently downloading the klite codecs
Mark
hypuk
Postby GJ51 » Wed Dec 29, 2010 2:40 am
Yes just add the video folder as you would any music folder in Settings. Also you need to add the file extensions to the mask in the Settings/General "Music mask" box in order for the files to show when you select the folder for display.
Postby hypuk » Wed Dec 29, 2010 6:29 pm
Ok
I've added the to the music mask .wmv and saved the settings but the filed don;t appear under the videos folder
Mark
hypuk
Postby GJ51 » Wed Dec 29, 2010 7:56 pm
Here's my music mask:
mp3 .ogg .aac .flac .m4a .wav .wma .mpg .mpeg .avi .mkv .ogm .mp4 .wmv .divx .flv
If you have any of those file extensions in your folders, they should show in the listings.
e.g. - Folder: C:\Videos
In that folder create a folder and name it "Test Videos" then copy several video file types into it for testing. If you set it up properly, there is no reason ti should not work. I've set this up many times under several SS versions going back to 3.9. It has worked every time without problems. Check you inputs carefully. Also make sure that the box is checked for the video folder you defined (Enabled) on the Music Folders screen.
I also uncheck all the transcoding boxes when I use an external player.
Postby hypuk » Wed Dec 29, 2010 8:36 pm
Nope nothing either.
I've attached a few screenshots of my setup so you can see where I might be going wrong
Mark
hypuk
Postby GJ51 » Wed Dec 29, 2010 8:48 pm
You need a space between the file extensions in the music mask. Easy fix. :D
Postby hypuk » Wed Dec 29, 2010 8:56 pm
THANK YOU!!!
Works a treat....just one more question, is there any way of changing my default media player?
hypuk
Postby GJ51 » Wed Dec 29, 2010 9:05 pm
In Windows 7, go to control panel, Default programs, Set your default programs, select the player you want to use, then "Set this program as default"
That will set the player to use all the default file types it can play.
Also - Subsonic looks much better in Chrome.
Postby hypuk » Wed Dec 29, 2010 9:14 pm
Thank you So much for your help...
Much appreciated
Mark
hypuk
