i have 8 tb of data, and i'm a broke college student. I cant afford to keep a separate copy of 250gb of musicGJ51 wrote:Just create and copy your music to a sperate Folder for your Subsonic music. Storage is cheap, just bought a Samsung F4 2TB for $79. 1.5 or 1TB drives are even cheaper.
alphawave7 wrote:I still don't follow. What is SS showing, that you do not want it to show? You can easily limit the file extensions/file types in mask as Gary described. I add music all the time, and SS scans and adds automagically.
i have a folder called "torrents", within that folder there are many other folders and files, not all of them are music. So SS is showing all my folders, even if they contain no music.alphawave7 wrote:I still don't follow. What is SS showing, that you do not want it to show? You can easily limit the file extensions/file types in mask as Gary described. I add music all the time, and SS scans and adds automagically.
do you realize how much work that will require if I wish to continue seeding my music torrents without making a separate copy? That means I have to manually move each folder to the new one, and manually change the folder location in my torrent client for each music folder I move so that it will continue seeding. And I would have to do that for every new album/song i download. That would take days just to get through what I have right now.3R3 wrote:simple solution would be to split your torrent folder into 2 folders, "music" and rest. then just let SS index the torrents/music folder.
And SS using tags for structure will never happen (hopefully) because IMO tags are just too shaky and noone seems to be able to put standardized tags. so for stabilities sake (its a server...) and speed i think this folder structure is great. you just have to handle it right
