SSL Certificate
SSL Certificate
Postby berthiggins » Sat Jan 22, 2011 11:19 pm
Hi Thanks for the new HTTPS feature
I have enabled it and it is working however browsers now complain of an invalid or out of date certificate.
Does anyone have any idea how to fix this?
I am using the standard Subsonic 4.4b1 install.
Thanks in advance for your help
berthiggins
Sorry
Postby berthiggins » Sat Jan 22, 2011 11:26 pm
Sorry this should be in help........................
berthiggins
Postby weelkin » Sun Jan 23, 2011 10:19 am
The Certificate uses by subsonic is not signed by a certificate authority which is accepted by your browser. You`ll have to get a new certificate from a certified CA. http://www.startssl.com/ offers free SSL Certificates which are accept by most browsers, but they are only valid for one year.
regards
weelkin
weelkin
Postby berthiggins » Sun Jan 23, 2011 11:35 am
Thanks for your help so far weelkin.
I have looked in my server (linux Ubuntu) and I cannot find where to install the certificate any help would be appreciated !
berthiggins
Postby weelkin » Sun Jan 23, 2011 2:58 pm
You' ll find a howto here:
http://forum.subsonic.org/forum/viewtopic.php?t=5295
but be sure to have the latest beta installed.With the latest stable you'll have to use a tomcat webserver or an apache proxy. Try to search the forums here, there are some howtos on that too.
regards
weelkin
weelkin
Postby berthiggins » Sun Jan 23, 2011 3:13 pm
berthiggins
Postby SCSI » Wed Feb 02, 2011 3:34 am
berthiggins,
Did you manage to install a signed by CA certificate for your unraid server? I am looking in to doing this as well.
SCSI
Postby haifa » Fri Feb 11, 2011 5:26 pm
Try this site http://www.xnynz.com/ to get the SSL certificate and also get the hosting,domain name register, domain appraisal, online file folder, ssl certificate etc.....
haifa
Postby stozher » Sat Feb 12, 2011 2:31 am
stozher
Postby humvee » Tue Feb 15, 2011 8:42 pm
this is nice but _where_ do i have to put in the cert? (directory)
humvee
Postby steven » Thu Apr 14, 2011 10:38 am
You could also create a self-signed certificate, it really depends how you want to use it, if it's just to prevent mitm attacks it shouldn't be any problem, I've been looking into this due to new laws in the netherlands which can only be looked after by putting taps on every internet connection so I'm planning on tunneling every subsonic connection.
ssl really provides what I need here!
steven
Postby GJ51 » Thu Apr 14, 2011 3:05 pm
humvee wrote:this is nice but _where_ do i have to put in the cert? (directory)
http://lmgtfy.com/?q=install+ssl+certificate :wink:
