Android Client audio restarting
Postby pcs800 » Fri Jan 28, 2011 6:43 pm
Ok I was taking part in another thread about this but they seem to have switched over to video and some motorola camcorder subject.
I do not have a bandwidth issue here, the songs download fine on both my droid and computers/web interface.
My subsonic server is on a 20meg line, plenty fast.
The issue I have makes subsonic useless on my android phone (HTC Hero).
Keep in mind this is audio only, I am not streaming video.
Lets say I pick a song to listen to, it starts downloading and a second later starts playing, but stops and restarts from the beginning. Does this over and over even if I had chosen multiple songs and the first is playing and fully downloaded and the second is downloading, the first will still stop and start over multiple times.
This did not happen the first few version of the android app I had installed. It is a fairly recent issue.
Could it have something to do with other audio players I have installed? I have PowerAmp installed as well.
pcs800
Postby GJ51 » Fri Jan 28, 2011 6:50 pm
It's possible. But you should check performance on other servers just to be sure it's a phone issue and not the server. Feel free to test on my public server.
http://maplegrove.subsonic.org guest for U & P
Also when you say you have a 20meg line, is that both up and down? For streaming, it's really only the upload speed from the server to the phone that's the important factor.
You might also check to see how full your sd card is.
re
Postby pcs800 » Fri Jan 28, 2011 7:03 pm
Yes it's 20meg both directions.
SD card is 56% full
Tried your server, same issue.
Here is my server if you want to see if it works ok for you
http://hostsalive.com:90
guest
guest
pcs800
Postby GJ51 » Fri Jan 28, 2011 7:25 pm
Everything runs fine on my EVO. What Android ver. is the Hero? Also is it stock or custom rom?
re
Postby pcs800 » Fri Jan 28, 2011 7:34 pm
I checked for updated on the phone it says it's up to date.
firmware version 2.1 update 1
baseband version 2.42.01.04.23
Kernel 2.6.29-bc0d2cff
build 2.36.556.1
software 2.36.556.1
pri 1.98_115
prl 19093
Stock rom
pcs800
re
Postby pcs800 » Fri Jan 28, 2011 7:53 pm
I just uninstalled the app from the phone, deleted the music directory from the card, reinstalled and get the same thing.
pcs800
Postby GJ51 » Fri Jan 28, 2011 7:54 pm
Just for fun, and it might help besides, try removing Subsonic from the phone, remove battery, reboot and reinstall Subsonic. I've seen it work before, maybe we can get lucky again.
re
Postby pcs800 » Fri Jan 28, 2011 7:56 pm
I shut the phone off every night, so it gets rebooted all the time.
Reinstalled app a few minutes ago.
Shutting down, remove battery starting back up now....
pcs800
Postby GJ51 » Fri Jan 28, 2011 8:03 pm
I would do the uninstall, then reboot/reinstall SS.
re
Postby pcs800 » Fri Jan 28, 2011 8:18 pm
Ok, I uninstalled, rebooted phone. Downloaded subsonic android app version 1.2 from 2010-02-09 and it works fine.
There is something with the newer builds that doesn't like my phone.
pcs800
re
Postby pcs800 » Fri Jan 28, 2011 8:27 pm
Just installed 1.9 and it works fine too. That's as far as I am going for now, it works and I see no reason to update until this gets fixed. Thanks for your help.
pcs800
Postby GJ51 » Fri Jan 28, 2011 9:17 pm
Great, glad it's woking. Nice library on you site.
re
Postby pcs800 » Fri Jan 28, 2011 10:29 pm
Me too, and thanks ;-)
pcs800
Users browsing this forum: No registered users and 62 guests
