Service unavailable error from localhost
Postby windstarpro » Sat Jan 29, 2011 1:38 am
Moved computer to another location(different ISP) and reinstalled Subsonic, now Im getting 'Service Unavailable' error from http://localhost/.
Is the service down, or am I missing something? I don't remember having any problems the first time I installed the program.
windstarpro
Postby GJ51 » Sat Jan 29, 2011 3:02 am
New Router?
Postby windstarpro » Sat Jan 29, 2011 3:46 am
Yeah, different router. Other ISP was unreliable. Shouldn't you be able to open your browser to subsonic local host no matter what?
windstarpro
Postby windstarpro » Sat Jan 29, 2011 3:57 am
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/music
Powered by jetty://
This is what I got when I right clicked on the sys tray Subsonic icon to open Subsonic in a browser to set it up. I had my port set to 2000 and I tried disabling Windows Firewall.
windstarpro
Postby GJ51 » Sat Jan 29, 2011 7:21 am
First read: http://monroeworld.com/android/subsonic/
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Set up port forwarding in your router to direct traffic on the selected port to your server.
Learn your external IP address assigned by your ISP.
Default Transcoding for video:
ffmpeg -ss %o -i %s -async 1 -b %bk -s %wx%h -ar 44100 -ac 2 -v 0 -f flv -
Stozher: mp4 > flv transcoding ffmpeg -v 0 -ss %o -async 30 -i %s -f flv -b %bk -r 30 -s %wx%h -acodec copy -
Postby windstarpro » Sat Jan 29, 2011 1:47 pm
See, thats the problem, Iam using port 2000, and I cannot get to the subsonic setup screen, when I try to go to http://localhost/ or since I changed ports, http://localhost/2000, the error I posted comes up. I cannot get to the browser screen. The systray icon is green, and everything appears alright, but I cannot go to the browser to set anything up. And, at the same time while this problem occurs, I have no problem browsing, down/uploading, or using FTP from the same computer.
Im stumped. Im about ready to switch to something else...
windstarpro
Postby GJ51 » Sat Jan 29, 2011 3:35 pm
So - you're telling me that you read through all the information I gave you, but you still don't know how to get to the Subsonic Control Panel?
Hint: You don't get to it through a browser.
Hint 2: First read: http://monroeworld.com/android/subsonic/
Postby stozher » Sat Jan 29, 2011 3:49 pm
stozher
Postby windstarpro » Sat Jan 29, 2011 4:29 pm
Yes, I know how to get to the control panel.
You open the browser to get to the above step, right? By right clicking on the Subsonic icon? Thats what Im getting from the directions. The option you are describing is not in the control panel.
I wasn't having problems till I upgraded to the newer version, maybe I'll just go back to the older version...
windstarpro
Postby GJ51 » Sat Jan 29, 2011 5:04 pm
I'm pretty sure you have a very minor glitch that should be easy to fix. Have you right clicked on the tray icon and selected "Open Subsonic in Browser?"
Postby windstarpro » Sat Jan 29, 2011 6:43 pm
Yeap, exactly. And the error messege I posted earlier is what Im getting. The Subsonic tray icon is green, and thats what is so baffling. I think I will try rolling back to a earlier version to see what happens...
windstarpro
Postby windstarpro » Sat Jan 29, 2011 7:08 pm
Tried 4.4beta, 4.3, and 4.2. all the same. Other than moving to computer from one place to another, I haven't changed anything. I don't think the computer has even updated since, and now nothing works. Only thing that happens, is the control panel starts, and is green. Shows using some memory, but thats it. Are there problems with Windows 7 maybe?
windstarpro
Postby GJ51 » Sat Jan 29, 2011 8:02 pm
One last try ...
Postby windstarpro » Sat Jan 29, 2011 8:31 pm
Yeap, and the error I listed before comes up on the browser that opens.
I just installed Subsonic on another computer with no problems. I think it is some setting on my computer that Im not aware of. The machine that it worked on was Vista, the machine that is not working is Windows 7.
windstarpro
Postby GJ51 » Sat Jan 29, 2011 10:03 pm
Java installed?
