Where are my podcasts downloading to?
Postby duckwars » Tue Feb 01, 2011 2:49 am
I am running ubuntu 9.10 (I believe...) and I saw in another post that it is in /var/subsonic/podcasts
but it doesn't appear to be there... I think the post was old.
Any ideas where my podcasts are downloading to, or how I can find this out? Thanks!
duckwars
Postby GJ51 » Tue Feb 01, 2011 3:22 am
I use the Windows version, so I don't know if it's the same, but I go to Settings/Podcast and define the directory in "Save Podcasts in" block at the bottom, just above the Save button.
Postby stozher » Tue Feb 01, 2011 11:57 am
/etc/default/subsonic (--default-podcast-folder=...) - used for daemon startup (overwrite options from "subsonic.sh")
/usr/share/subsonic/subsonic.sh (SUBSONIC_DEFAULT_PODCAST_FOLDER=...) - used for user desktop startup
Create manually this folder if not exist (check permissions, need be same as SS unix user). After add podcast in SS wait for downloading. Some podcasts is a limited download speed and response... Just wait and see for errors.
Example from my "/etc/default/subsonic":
SUBSONIC_ARGS="--home=/srv/subsonic --port=80 --max-memory=512 --default-music-folder=/srv/subsonic/Music --default-podcast-folder=/srv/subsonic/Podcasts --default-playlist-folder=/srv/subsonic/Playlists"
stozher
Postby duckwars » Tue Feb 01, 2011 11:27 pm
stozher wrote:/etc/default/subsonic (--default-podcast-folder=...) - used for daemon startup (overwrite options from "subsonic.sh")
Thank you kindly, sir.
duckwars
