https & http concurrent connections?
Postby wizardai » Thu Feb 10, 2011 7:40 pm
Is there a way on 4.4 to have both accessible at the same time? Or does it have to be one or the other?
wizardai
yes
Postby john.jays » Fri Feb 11, 2011 7:13 am
This should be possible if you use different ports for http and https.
SUBSONIC_ARGS="--port=8080 --https-port=8090 --max-memory=100"
May be worth it to name your OS.
john.jays
Postby wizardai » Fri Feb 11, 2011 4:49 pm
Thanks for the reply. I'm on BSD.
In my subsonic.sh I have modified the file to reflect my needs. So I have:
SUBSONIC_HTTPS_PORT=19999
SUBSONIC_PORT=20000
But for some reason, I can only connect to https and not http.
So if I default the value to
SUBSONIC_HTTPS_PORT=0
I can get to http again.
The ports have been opened and can be connected to with different configs. It's just at the same time I haven't been able to.
Any ideas?
Oh and the reason I would like both is because on the subair client, it yells about not having a signed certificate. So I'd like to use http only on that... the connection is already going through a tunnel to the server so there's no worries there.
wizardai
Users browsing this forum: No registered users and 35 guests
