Is it possible to downsample to HE-AAC v2 (aacPlus) ?
Postby ozamora » Fri Feb 11, 2011 6:24 pm
On my Android phone I am able to select a bitrate when using 3G/HSPA. Currently set at 128 kbps.
Wondering If I can downsample to AAC+ @ 64 or 48 kbps instead. Wan't to squeeze more quality using less bandwidth if possible.
ozamora
Postby GJ51 » Fri Feb 11, 2011 7:07 pm
There is a thread regarding transcoding to OGG@64kbps which was being done to get good quality playback but I can't find it. The thrust of it was that those users felt that ogg was the best format for quality at lower bit rates. You may want to check that out as an option, using Stozher's transcoding found here:
http://forum.subsonic.org/forum/viewtop ... hlight=ogg
EDIT: Here's the thread I referenced:
http://forum.subsonic.org/forum/viewtop ... sc&start=0
Postby ozamora » Fri Feb 11, 2011 7:36 pm
Thanks. With the same idea I can try with the Nero AAC+ encoder.
http://www.nero.com/enu/downloads-nerod ... -codec.php
ozamora
Users browsing this forum: Bing [Bot] and 23 guests
