Subsonic worked fine until I donated
Postby nofuneral » Sun Feb 20, 2011 6:20 pm
I haven't changed any settings on my android phone. I did, around the same time, update the Subsonic Music Streamer on my PC but there has been no Android app update.
Any help?
Whenever I try to connect (the settings have stayed the same both on my phone and in the localhost) to my library or playlists it says "Contacting server, please wait" and then "A network error has occurred. Retrying 1 or 4." It tries 4 times, no luck.
The same thing happens when I go to "Settings > Server Name > Test Connection"
I love this software but now it's useless to me, right after I donated : )
Thanks for any assistance!
nofuneral
Temporary Fix
Postby nofuneral » Sun Feb 20, 2011 7:58 pm
It's less than ideal to me, but I was able to make it work by changing the Server name. All I did was the the number "2" at the end of the old name, set up a new server on my phone with that name and it worked. I'd like the old name instead, if anyone knows why it might not be working anymore.
nofuneral
Postby GJ51 » Sun Feb 20, 2011 11:11 pm
First read: http://monroeworld.com/android/subsonic/ This is the Windows tutorial but most of the concepts apply to any setup. Specific setup instructions for other Operating Systems are available in the Tutorials section. http://forum.subsonic.org/forum/viewforum.php?f=6 and on the Subsonic website at http://www.subsonic.org/pages/installation.jsp
Never use port 80 - ISP's often use it or block it. 8080,8081, work fine. 808X always works. I've seen others use different port numbers that have caused install failure.
http://www.java.com/en/download/faq/java_win64bit.xml
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080, 8081, etc.
Postby nofuneral » Sun Feb 20, 2011 11:28 pm
Everything you say sounds correct, and I would have gone through the trouble of setting that same configuration up already, but without changing any router settings, I was able to get the server working again simply changing my old yourservername.subsonic.org to yourservername2.subsonic.org.
With that change alone for some reason it's working fine again. I can't, however, change it back to my old yourservername.subsonic.org. If I do, it has the same error.
Thanks for the info though! If nothing else works, I'll start back at that method.
nofuneral
