Is it possible to install Subsonic to My Book Live?
Postby oaf » Mon Feb 21, 2011 7:16 pm
Hello...
I'm considering to install Subsonic to MBL. Are there any possible problems?
Thank you in advance.
Alexander
oaf
Re: Is it possible to install Subsonic to My Book Live?
Postby oaf » Sat Mar 05, 2011 6:40 pm
oaf wrote:Hello...
Alexander
Actually I've done it and Subsonic works there.
Not so fast but enough to stream inside network.
In case of outside... some gaps appeared. So I need to know how to optmize
the data flow...
oaf
Postby GJ51 » Sat Mar 05, 2011 7:03 pm
The best way to optimize performance is to use media that doesn't require any transcoding.
http://www.longtailvideo.com/support/jw ... io-formats
Postby 3R3 » Sat Mar 05, 2011 7:29 pm
I'll include your successful installation in the unofficial NAS compatibility list
3R3
Postby oaf » Sat Mar 12, 2011 7:37 pm
3R3 wrote:I'll include your successful installation in the unofficial NAS compatibility list
OK. I've used Subsonic Debian version. And slightly renew the transcoders which were existed on MLB. Actually it works rather good. With transcoding from FLAC to MP3. But it should be tracks. Some problems were there as I've tried to use big FLAC files as full images of CD.
One more thing. I'm using only small covers (like cover.jpg and folder.jpg)
instead of use the big scans which sometimes provided with albums.
Last... MLB has about 256Mb memory. So I've defined 120M in subsonic settings file. Currently Java for Subsonic eats about 40% of whole memory.
oaf
Re:
Postby Aqualung » Tue Sep 13, 2011 6:42 pm
oaf wrote:Actually it works rather good. With transcoding from FLAC to MP3. But it should be tracks.
Any particular reason (other than bandwidth) why you'd be transcoding FLACs to mp3s?
Aqualung
Postby species8472jj » Wed Nov 02, 2011 7:04 pm
Do you have instructions on how to install Subsonic on My Book Live?
There seems to be instructions on other NAS servers, but not this on (and of course this is the on I have).
I saw it can work - just not sure how to do it.
species8472jj
Postby ace518 » Wed Feb 22, 2012 8:45 am
I'll work on a real write up later. But FYI, I just went from the default install of subsonic to having on tomcat and WOW, what a difference in speed. MUCH better.
Oh, and yeah... it definitely can run on the my book live.
ace518
Postby bushman4 » Wed Feb 22, 2012 7:53 pm
Totally agree. Moved from standard install to Tomcat a year ago and haven't looked back.
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby MarcelPlemoghar » Tue Apr 10, 2012 1:23 pm
ace518 wrote:IBut FYI, I just went from the default install of subsonic to having on tomcat and WOW, what a difference in speed. MUCH better.Oh, and yeah... it definitely can run on the my book live.
I have around 15'000 Songs (only mp3) and searching and browsing around with the web gui was a bit slowley, compared to my install on a separated laptop/server. I would like to hear any other experiences?
Questions:
  • Does installing on a tomcat help speed up thinks realy that much (even on a 256mb box like "my book live")?
  • do you run the tomcat behind the default apache werbserver
  • I simlinked the var/subsonic to the storage partition, due the low space on the /, any other pitfalls?
  • there is no wake-on-lan, does subsonic prevent the harddisk to go in sleep mode.. (may I checkout with powertop later...)
  • For me it was very easy to install a) the open java stuff and then b) the default debian packages from subsonic. But I had to compile lame (and if I would use also ffmpeg) manually (the included from the packages didn't worked), any other stuff to compile manual.. whats for example about id3 tag edditing?
bye
Marcel
MarcelPlemoghar
Postby tnt533 » Sun Sep 16, 2012 6:51 pm
This thread has seemingly died. I too would like to install tomcat and subsonic on my newly purchased My Book Live 2tb and was looking for a little instruction. I'm wading through it solo and will post back with what I did assuming I can get it running.
ace518? Did you ever manage to get that howto written?
tnt533
Postby MarkT40 » Sun Oct 07, 2012 9:46 am
Hi there
Could anyone give me a real basic step by step guide onhow to get subsonic server running on a WD My Book Live?
MarkT40
Postby MarkT40 » Wed Oct 10, 2012 7:21 pm
Anyone at all able to give help on this? I'm stuck using Twonky at the moment which I find to be nowhere near as good as subsonic.
MarkT40
Postby GJ51 » Wed Oct 10, 2012 7:50 pm
There have been varying degrees of success installing Subsonic on storage devices. I have no specific information regarding the WD Live or any other particular storage device because of the inherent limitations of those devices.
They are designed to handle storage and transfer of data stored on the device. Manufacturer's don't spend more on cpu power for these devices than they need to in order to remain cost competitive in a tight market. As a result they are not designed to meet the additional load of hosting a webserver. Perhaps if you figure out the installation you may get reasonably acceptable performance with music if you don't set up any transcoding, but this isn't the function that the unit was designed to handle.
You'd be much better off with any throw away PC that can be repurposed even if you get a cheap refurb from Tiger direct or an obsolete server from ebay. My fastest server was a used HP workstation I picked up on ebay. It has dual quad core 2.83GHz CPU's 16GB ram and came with 2 - 250GB hard drives in a SOLID steel workstation case for $600. You don't need anywhere near that kind of power unless you wnat to host and transcode blue ray quality video on Subsonic.
Any cheap throw away ebay PC will run circles around an installation on a storage device.
http://www.ebay.com/itm/Dell-XPS-200-Mi ... 5aea3da905
Less than $50.
Add a 2TB hard drive and you've got a Server for less than $200.
http://www.ebay.com/itm/HP-Compaq-DC780 ... 2ec246fe8f
Core 2 duo 3.0 GHz 2 GB for $60 NO BIDS.
You can get WHS 2011 on Newegg for $50 if you don't want to use Linux for free.
It's so cheap and easy to set up a functional server that works really well with Subsonic that trying to shoehorn it into a storage device doesn't make much sense.
http://stores.ebay.com/JCMPARTS/Compute ... 34.c0.m322
PC & OS $100
Hard drive as low as $50
$150 - your up and running on a real server that can handle Subsonic.
http://www.newegg.com/Product/Product.a ... 6832416443
http://www.newegg.com/Product/Product.a ... 6822152244
Postby BKKKPewsey » Wed Oct 10, 2012 8:52 pm
But don't forget Gary's $50 consultancy fee :D
Users browsing this forum: No registered users and 44 guests
