simple upgrade help
simple upgrade help
Postby henning » Fri Mar 11, 2011 2:22 pm
I'm running Subsonic standalone on 2 Linux machines in version 4.1
Now I need/want to upgrade to the latest version.
Sofar all upgrades ended with the loss of all user data.
Is there a simple way to upgrade with out loosing this data ?
System Debian (Kanotix) with Xampp
Tks
Henning
henning
Postby 3R3 » Fri Mar 11, 2011 10:45 pm
backup the db folder in the subsonic dir, and "subsonic.properties" in the subsonic folder. install over old SS folder and drop the saved files back in. That should set you straight :)
3R3
Postby henning » Sun Mar 13, 2011 5:13 pm
tks, but at least for the first installation it did not work as expected.
Same as before , user data lost.
I will see if I can manage it properly with the second one.
Brgds
Henning
henning
Re: simple upgrade help
Postby flockmock » Sun Jan 15, 2012 3:44 pm
hello henning,
did you were successful? I have the same problem and would like to upgrade without loosing my settings....
thanks, f.
flockmock
Postby BKKKPewsey » Sun Jan 15, 2012 5:17 pm
The user settings etc are stored in the subsonic.script file in the db directory so make sure you back that up 1st
