Can't Register/Log In To Subsonic
Postby Son of Spam » Mon Mar 21, 2011 1:01 pm
Problem Description: I've downloaded and installed subsonic. But I can't get past the login screen.
Troubleshooting Steps: Changed port 80 to port 8080 but not sure if this would help.
Playback Application and version: Presumably, the standard Subsonic Web Interface, but not sure.
Subsonic Version: Again, presumably 4.4.beta1 (build 2132) – January 18, 2011, but not sure.
Server Version: Have no idea, because I can't login. I'm assuming it's jetty-6.1.x, java 1.6.0_23, Windows 2003 (130.8 MB / 145.0 MB) but I don't know.
I'm running an HP Mediacenter m7060N computer with Windows XP Service Pack 3. Version 5.1 (Build 2600.xpsp_sp3_gdr.100216-1514: Service Pack 3)
Son of Spam
Postby GJ51 » Mon Mar 21, 2011 3:50 pm
4.4 is out of beta. You should uninstall SS, delete the C:\Subsonic directory and start over.
Here are the guidlines I use. READ ALL the material af few times to get an understanding of what you're doing. Take your time. It is complicated for a newbie, but it is doable, and you'll learn a lot about your system and networks in the process that will serve you well far into the future. Don't try to get it done in a hurry. Take your time and enjoy what you're doing and you'll have a much better chance of getting this set up properly. I have 3 SS servers that run 24/7 - rock solid - never crash. Here you go:
http://www.java.com/en/download/faq/java_win64bit.xml If you have SS installed, uninstall it and delete the Subsonic directory (Windows).
Disable any DHCP services in any VOIP equipment or other additional routers you have. Only ONE router/device per network should handle DHCP assignments.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc.
Test your setup by entering your external IP:port# to see if it connects. e.g. http://x.x.x.x:8084/ If it works, you're good to go.
(IP edited by moderator)
Postby Son of Spam » Sun Apr 03, 2011 1:48 am
Wow! Thanks for the detailed tips, Gary! :D
However, I don't have a router, so I believe those instructions would be irrelevant to me.
So I followed your instructions beyond that and it eventually took me to the Subsonic log in page. Despite the "Set Admin Password" instruction on the http://monroeworld.com/android/subsonic/ page, I get no indication in red saying "Subsonic is not secured. Please log in with username and password "admin", or click here. Then change password immediately."
It, instead, takes me to https://x.x.x.x:444/login.view?error and I cannot log on.
This is the main issue preventing me from signing on and enjoying Subsonic.
I'm using Firefox 3.6.16, if that helps.
Thanks.
(IP edited my moderator)
Son of Spam
Postby GJ51 » Sun Apr 03, 2011 3:30 am
Disable SSL and try it.
Postby Son of Spam » Sun Apr 03, 2011 4:06 am
GJ51 wrote:Disable SSL and try it.
Sorry for my ignorance, but what is SSL?
Thanks.
Son of Spam
Postby GJ51 » Sun Apr 03, 2011 4:44 am
Open the SS Control Panel, Settings tab, uncheck the box that says enable SSL.
How can you be connecting on 444 over https if you didn't set up SSL connection? It's not enabled by default.
Postby Son of Spam » Sat Apr 09, 2011 9:46 pm
GJ51 wrote:Open the SS Control Panel, Settings tab, uncheck the box that says enable SSL.
But the thing is, I don't have the option to enable/disable SSL.
Here's my Settings panel:
And here's my Status panel:
Son of Spam
Postby supra92 » Sat Apr 09, 2011 10:04 pm
I've never used the Windows version before, but that Control panel screenshot you showed indicates SSL:
Look at the checkbox that's checked, with "Enable https on port" with 443 in the box.
https = SSL. Not in a strict sense, but they're generally used as semi-interchangeable terms. the "s" in "https" stands for Secure, as does the first "S" in "SSL". (HyperText Transfer Protocol Secure, and Secure Socket Layers, respectively).
So your https checkbox there is your SSL enable/disable option.
Hope this helps, and cheers,
Supra92
supra92
Postby alphawave7 » Sat Apr 09, 2011 10:16 pm
Uncheck that 'Enable https on port' box, and since the service is stopped, click 'Start' on the Status Tab. I've been able to access your login with no issues. :)
Postby Son of Spam » Sun Apr 10, 2011 12:25 am
alphawave7 wrote:Uncheck that 'Enable https on port' box, and since the service is stopped, click 'Start' on the Status Tab. I've been able to access your login with no issues. :)
MY Login??
You're clearly having better luck than me, lol!
Okay, sorry to be such a pain (thank you all for your patience with me!), but here's my updated Settings panel:
The updated Status panel:
Then I open Subsonic in my browser and get this login page:
But when I try to login using my Subsonic Forum Username and Password, all I get is this:
And for the life of me, I can't understand why.
Son of Spam
Postby alphawave7 » Sun Apr 10, 2011 12:33 am
It may well NOT be your forum name/password...indeed it's most likely not. Check your pm box. :)
Postby Son of Spam » Sun Apr 10, 2011 12:50 am
Should I delete any cookies?
I'm wondering if that my be preventing my logging in.
Son of Spam
Postby Son of Spam » Sun Apr 10, 2011 1:21 am
YAY!
OKAY, I'M IN!
Question: how do I get my own "yourname.subsonic.org" to listen to my music over the internet?
Son of Spam
Postby alphawave7 » Sun Apr 10, 2011 1:26 am
Postby Son of Spam » Sun Apr 10, 2011 1:43 am
And I'm presuming I would use the same host name on the Android app?
(Thanks for all your help, BTW! I can't thank you enough!)
Son of Spam
