Can't Play Audio Files
Postby jeremy_loo » Tue Apr 19, 2011 12:39 pm
I'm newbie to Subsonic and have to agree that this is a great program.
I having problem playing audio file.
I have no problem with Video.
I have tried using Firefox and IE. When I point to the "Play" button, the link states "Javascript:noop()" and in IE, when I click on the "Play", it states "error on page".
I have tried both local & remote (network & internet).
BTW, Subsonic is installed on my Ubuntu 10.10.
Your help is greatly appreciated.
Thank you
jeremy_loo
Postby GJ51 » Tue Apr 19, 2011 3:18 pm
What happens when you select an audio file. What type of audio files? After a failed attempt. go to the "About" link and copy the log output and post here.
Postby jeremy_loo » Tue Apr 19, 2011 3:54 pm
GJ51 wrote:What happens when you select an audio file. What type of audio files? After a failed attempt. go to the "About" link and copy the log output and post here.
Hi Gary,
I'm playing mp3 files and the log output as below.
[4/19/11 11:51:43 PM SGT] DEBUG InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) av_interleaved_write_frame(): Operation not permitted
Jeremy
jeremy_loo
Postby GJ51 » Tue Apr 19, 2011 4:33 pm
I'm a Windows guy, so I'm not the best one to help you, but I'd be sure to check that I had the latest Java installed properly and check to see if this may be a permissions related issue. I also would suggest trying Chrome as the browser for web access just to see if this is an IE issue.
Postby jeremy_loo » Tue Apr 19, 2011 4:40 pm
GJ51 wrote:I'm a Windows guy, so I'm not the best one to help you, but I'd be sure to check that I had the latest Java installed properly and check to see if this may be a permissions related issue. I also would suggest trying Chrome as the browser for web access just to see if this is an IE issue.
Yeap...did try on Chrome...the same result.
I think it's the permission issue too. But do not know where to change the permission. This is my 1st time using Ubuntu/Linux OS.
jeremy_loo
Postby GJ51 » Tue Apr 19, 2011 4:55 pm
If you pm Alphawave7 or 3R3 I'm sure they can help you. You might also try doing some forum searches as I'm sure this has been addressed before.
Postby jeremy_loo » Tue Apr 19, 2011 5:09 pm
Thanks Gary,
I've PM them and awaiting for their reply.
jeremy_loo
Postby jeremy_loo » Wed Apr 20, 2011 3:44 am
I have "disabled" all transcodes and the result is the same.
I'm trying to see the link of the icon by pointing to it. And this is what I found...
1. When point to the "Play" icon => javascript:noop();
I noticed that " javascript:noop()" will appear if it is a directory. However, this is a mp3 file.
2. When point o the "Download" icon on the same song, I get a url link.
Not sure if it's Java issue...as I get on the browser "javascript:noop()". I have installed Java 6.
jeremy_loo
Postby lildadou » Wed Jun 15, 2011 7:43 am
I have the same problem but only with one-specific album encoded in FLAC 6-channels
lildadou
