Skip / do not scan subfolder
Postby demonstreamer » Thu Apr 21, 2011 9:02 pm
I have a folder called "Rock" with hundreds of folders under it by Artist. Some of the folders I do not want Subsonic to scan. Is there a way to skip/block certain folders?
demonstreamer
Postby GJ51 » Thu Apr 21, 2011 10:08 pm
Move them to a different folder, one not listed in Settings/Music Folders :idea:
Postby demonstreamer » Fri Apr 22, 2011 6:12 am
GJ51 wrote:Move them to a different folder, one not listed in Settings/Music Folders :idea:
Obviously thats a solution but not then my music wont be organized the way I would like on my hard drive.
demonstreamer
Postby GJ51 » Fri Apr 22, 2011 6:33 am
Hard drives are pretty cheap. :wink:
Postby demonstreamer » Fri Apr 22, 2011 6:50 am
GJ51 wrote:Hard drives are pretty cheap. :wink:
What does that have to do with buying another hard drive? I have 5 hard drives, with TBs free. I'm just trying to find out if there is a way to filter folders.
demonstreamer
Postby GJ51 » Fri Apr 22, 2011 7:02 am
Not at this time.
Postby bushman4 » Fri Apr 22, 2011 6:32 pm
Not that I want to argue with Gary, but...
Change the user account that Subsonic is running under, and then deny that user account access to the folders in question. That should accomplish what you want.
NB: not tested. I don't really know what subsonic will do when denied access to the folders. I would definitely do a re-scan and watch the log right after you make these changes.
HTH,
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Fri Apr 22, 2011 8:27 pm
Let me be permitted to rephrase.
Currently not a feature available in Subsonic at this time, to the best of my knowledge. :wink:
Postby demonstreamer » Sun Apr 24, 2011 9:54 pm
GJ51 wrote:Let me be permitted to rephrase.
Well, this is a feature. Thanks for the help though.
demonstreamer
