Search broken in 4.4
Postby zapt0 » Tue Apr 26, 2011 8:51 pm
Using windows installer of 4.4, I have added folder with substantial amount of files (~50000) which took only about ten seconds. I can see all the files in the list but they are not searchable, not even by folder name. Searching for anything at all gives no results.
Troubleshooting Steps: Tried readding folder, no dice.
Playback Application and version: Latest web interface or android client.
Subsonic Version: 4.4 (build 2172) – February 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_07, Windows 2003 (41.1 MB / 49.6 MB)
Hardware Platform: Windows Server 2003
Java Memory Limit: 100MB
Please advise!
zapt0
Postby kermit22 » Wed Apr 27, 2011 6:47 pm
Are you able to search now? The search index should have rebuilt itself last night.
kermit22
Postby zapt0 » Wed Apr 27, 2011 8:05 pm
kermit22 wrote:Are you able to search now? The search index should have rebuilt itself last night.
Hello!
Yes, searching now seems to work when I left it running overnight. I really feel an initial folder add should trigger a full refresh or at least give some information.
zapt0
Postby kermit22 » Wed Apr 27, 2011 9:27 pm
If you add music or video in the future and you don't want to wait for the nightly scanning you can manually update your index through the web at Settings>Search and then click the "Update search index now." link.
kermit22
Postby zapt0 » Thu Apr 28, 2011 8:49 am
kermit22 wrote:If you add music or video in the future and you don't want to wait for the nightly scanning you can manually update your index through the web at Settings>Search and then click the "Update search index now." link.
Must have missed that button, thanks!
zapt0
