How to setup video streaming??
Postby twos49 » Sat Apr 30, 2011 1:21 pm
Hello all Here's my setup
subsonic verison:4.4
Installed on WHS in
Apache Tomcat/6.0.29, java 1.5.0_22, Windows 2003 without HTTPS. I've tried and tried to get HTTPS to work but can't I'll ask about that in another post.
Issue/problem:
I have purchased the license and successfully updated subsonic from demo to full. I don't know how the video streaming functionality is suppose to work. I have created a "Videos" folder and pointed it to the video folder on the server (D:/shares/video) the same format as my music folder. However does not "pick up" the videos in that folder. I don't see them to the left where all the music is displayed. Also I'm not sure how to play the video once it is found. What I mean, is video suppose to play in a player in the subsonic website?? Am i suppose to install a special video player inside of the subsonic website? Is the video streaming functionality only limited to the mobile apps? I searched the forum but there isn't much to help me out except to just point to a video folder. I did a search on "video" and "video streaming".
twos49
Re: How to setup video streaming??
Postby Aethies » Sat Apr 30, 2011 9:19 pm
twos49 wrote:Hello all Here's my setup
Installed on WHS in
Issue/problem:
First of all, welcome to subsonic!
Second, I have set up separate folders for music and video. Then go to the Settings | Music Folders and add each one separately.
After that, click on the Advanced settings and verify that you have your VIDEO MASK similar - .avi .mpg .mpeg .flv .mp4 .m4v .mkv .mov .wmv .ogv - That is the default settings.
Just to ensure you didn't inadvertently clear that out. I know I did the first time I was adding new formats.
Lastly, No. You don't need a player installed if you have flash. The site uses embedded flash player. It is actually a lot better now with the update than it used to be in the past.
Hope this helps....
Aethies
Ubuntu Server 12.04
3,281 artists
9,432 albums
113,608 songs
2636.09 GB (10,769 hours)
Aethies
Postby Minime » Mon May 02, 2011 8:22 am
The only thing i would add to the post above is to enable the Active transcodings for the video formats you require like avi > flv, mp4 >flv and so on by going to: Settings > Players(scroll to the bottom and put a tick next to the ones you require) then save. You may have to do this for every user you want to stream videos.
Best Regards
Minime,
Subsonic 4.6 | Ubuntu 10.04 LTS inside a VMWare host
Galaxy SII with ICS 4.0.1 & Android App v3.0 Combo
XBMC Dharma with t0mm0-xbmc-addons
+ A few custom Mods
Minime
