JAVA problem
JAVA problem
Postby beatdrp » Mon May 02, 2011 3:42 pm
The following error appears in the left pane when logged into my subsonic account on a remote machine:
Exception java.lang.OutOfMemoryError
Message Java heap space
Java version Sun Microsystems Inc. 1.6.0_24
Operating system Windows XP 5.1
Server jetty-6.1.x
Memory Used 73 of 96 MB
Stack trace java.lang.OutOfMemoryError: Java heap space
I've tried uninstalling and reinstalling the latest JAVA. I've tried it in multiple browsers (IE7 and Chrome). I've rebooted. I keep getting the same error however.
Any suggestions?
beatdrp
Postby alphawave7 » Tue May 03, 2011 3:41 pm
Use the SS console to increase your memory..try 256.
Postby beatdrp » Fri May 06, 2011 3:12 pm
That did the trick. Thanks!
beatdrp
Postby steez » Mon May 09, 2011 3:22 pm
alphawave7 wrote:Use the SS console to increase your memory..try 256.
Could you tell me the code on how to do this?
steez
Postby alphawave7 » Tue May 10, 2011 4:00 am
On windoze, the console is accessed from the Subsonic icon in the system tray.
Postby steez » Tue May 10, 2011 4:32 am
Thanks, on debian install it's here
http://forum.subsonic.org/forum/viewtopic.php?t=6657
steez
