Ubuntu 11.04 and SubSonic :(
Postby edina » Wed May 04, 2011 4:51 pm
hi every one,
Is there a solution to get subsonic to work withn Ubuntu 11.04?
when ive upgradet the trouble started.
when i try to access my Subsonic it says
HTTP ERROR: 404
NOT_FOUND
RequestURI=/index.view
Powered by Jetty://
ive tried a clean install of subsonic, same bug
and it commes up with an error.
and when i try the standalone version, same thing AGAIN :(
edina
Postby edina » Fri May 13, 2011 6:37 pm
wow....so much help here:(
i cant believe im the only one who cant get it running
on Ubuntu 11.04?
edina
Postby GJ51 » Fri May 13, 2011 6:54 pm
It's the middle of the day. Some of the members are working. Linux isn't my specialty or I'd be glad to help you. Be patient, I'm sure one of the Linux guys will give you help once they log in.
it's a forum, not a chat support line. :wink:
RE: Ubuntu 11.04 and SubSonic :(
Postby SparkyRih » Sun May 15, 2011 9:56 pm
I'm pretty now to Ubuntu, but I managed to install everything without any issues...
You did install the openjdk-6-jre, and after that the debian package of Subsonic?
VMWare ESXi 5.5 > Ubuntu 16.04 > Subsonic 6.0 (Modded with PHP based registration feature)
SparkyRih
Postby aTommyC » Wed May 18, 2011 7:37 pm
I upgraded my 10.10 to 11.04 yesterday, no problems at all. Using Tomcat6, though...
aTommyC
Postby garyjmellor » Wed May 25, 2011 8:05 am
I'm also running 11.04 with Subsonic 4.4. Had some issues with portforwarding which another forum member assisted with. Other than that I'm now up and running. I should point out that this was a fresh install and not an upgrade of Ubuntu with Subsonic already running.
garyjmellor
Postby 3R3 » Fri May 27, 2011 12:30 am
I have to say, as a linux guy: I am compelled to help you after I read you bitch about the support in here after 106 minutes!
...and compelled to use irony to make the pain go away...
3R3
