Cannot Login
Cannot Login
Postby misticjeff » Thu May 12, 2011 9:36 pm
I have scoured the forums, I have gone step by step through Monroe guide and cannot login.
1. I change the port in the server to 8080 and restart the server.
2. I then open up subsonic in the web browser and see the Username and Password fields.
3. I enter "admin" in both the username and password fields (without the quotes) and hit log in.
4. It tells me "wrong username or password" and gives me no other options.
Please someone help me! I've uninstalled and reinstalled 3 times now with the same result every time.
Running a windows pc with Win 7 64bit and have tried in Firefox, I.E. and Chrome.
Jeff
misticjeff
Postby GJ51 » Fri May 13, 2011 3:38 am
Are you deleting the C:\Subsonic directory before you reinstall? If not then it won't reset the password.
Postby misticjeff » Fri May 13, 2011 2:13 pm
Thanks.
That took care of that.
Now cannot get my port forwarding working. Not sure all this trouble is worth it really.
misticjeff
Postby GJ51 » Fri May 13, 2011 2:27 pm
It's worth it, but it isn't for the feint of heart. You can see the result at my site listed at the bottom of the post is you want to see a live demo.
Here are my notes for the best way to set up. Take the time to read carefully a few times till everything sinks in. Once you understand what's happening it gets a bit easier.
http://www.java.com/en/download/manual.jsp If you have SS installed, uninstall it and delete the Subsonic directory (Windows).
Disable any DHCP services in any VOIP equipment or other additional routers you have. Only ONE router/device per network should handle DHCP assignments.
Check the Subsonic Control Panel to make sure it's using the right port you're going to use. I typically use 8080 - 440, 8081 - 441, etc. Skip 8083 - 443 to avoid conflicts with WHS.
