movie streaming fine 20 minutes then the picture gets itchy
Postby Schakine » Tue Jun 07, 2011 8:33 pm
Well i stream movies from my pc both mkv and avi to an Acer A 500 tablet
Everything fine the first twenty minutes then the pictures lags and become more static
Had increased memory on subsonic tray icon toi 1200 without success
Of course,i can watch to the end and the sound is fine but it is quite desapointing as the start is just fine
Do someone knows what i can do?
My tablet has a good memory built in and i had increase the cache to one Go without success either
Thank you
Schakine
Postby GJ51 » Tue Jun 07, 2011 8:43 pm
It might be an issue with the transcoding on the host PC. I updated ffmpeg to a newer release that enables the use of more than one core for the transcoding, and that helped a lot. Video performance also works the best when you bypass the transcoding altogether and do the playback in a format that plays natively. i use mp4 for the desktop and flv for mobile playback.
Postby Schakine » Tue Jun 07, 2011 9:12 pm
Thanks Gary
Seems u never sleep
Did u dl ffmpeg and where from?
And where should i put tb
He filter tto in subsonic
Schakine
Postby GJ51 » Tue Jun 07, 2011 11:20 pm
I'll sleep when I'm dead. :wink:
When you're retired, you sleep whenever you feel like it.
Here's the instructions for updating JW Player and ffmpeg:
To update JW Player to the newest version, go to http://forum.subsonic.org/forum/viewtopic.php?t=5977
and read the instructions. Read the whole thread as you'll see there is the long way and the short way. I use the method I suggested as it seemed to be less time consuming. IF I want to know what version of the player I'm running, I'll just fo a right click on the installed player and it will tell me what version it is.
I just downloaded JW 5.6, extract player.swf, rename it to the current name in the subsonic/jetty/xxxx/webapp/flash folder and replace the original file. Rename JW Player 5.4 to Old JW Player 5.4. then drop player.swf into the directory and rename it to JW Player 5.4 when you're done it'll be named 5.4 but if you right click on it in SS you'll se that it's really 5.6
ffmpeg - go to http://ffmpeg.zeranoe.com/builds/ and download the latest static build for your system. This site is for Windows builds. Check http://www.ffmpeg.org/download.html for other OS's. I just extracted the ffmpeg.exe and replaced thet file in C:\Subsonic\transcode
I found that the newer ffmpeg enabled multi-core transcoding, which really helps a lot. The version that comes with SS only uses one core per video stream. I've mentioned this to Sindre, so hopefully he'll incorporate a newer build in his next beta.
Postby Schakine » Wed Jun 08, 2011 6:21 am
Thank you
I will do that and try
I assume you install everything on pc where the server is and not in the tablet where i want to stream?
I am half retired too (63)
Let u know if i find improvement
Good night
Schakine
Postby Schakine » Wed Jun 08, 2011 7:14 am
Much much better!
Thank you so much...
Enjoy your retirement and keep the good work..
Schakine
Postby Schakine » Wed Jun 08, 2011 10:27 am
story of my life
i thought it was better but the same problem again
after thirty minutes of continuous playing the picture gets static and loose fluidity..
Dont understand..
The only way is to stop the movie and start again from the time it was stopped..looks like a cache problem but I have increased the memory limit and my tablet have plenty of memory avalaible..
Could it be a Windows 64 bits problem (i have windows 7 64 bits)
i will try ffmpeg .exe in 32 bits instead..
Thank you anyways!
Daniel (Paris)
Schakine
Postby GJ51 » Wed Jun 08, 2011 2:51 pm
What file type and transcoding settings are you using?
Postby Schakine » Wed Jun 08, 2011 6:42 pm
I am using normal standard subsonic transcoding settings to stream avi and mkv..
one point i just tried to stream mkv through the internet on my laptop in my office and it worked fine..
this could show i got a problem with the subsonic app i am using on my acer A500 tablet as this tablet is Android Honeycomb 3.1..
Do you know if the subsonic app downloadable from the android market is android 3.1 ready or maybe not...
Schakine
Postby GJ51 » Wed Jun 08, 2011 7:16 pm
Sorry, haven't seen any other feedback on Honeycomb yet.
Postby Schakine » Wed Jun 08, 2011 8:59 pm
Ok Gary
just await and see if anyone experienced same issue with Honeycomb and the actual only one subsonic app for Android
Schakine
