Some albums won't play - lame:excess arg Before error
Postby jbraveman » Mon Jun 13, 2011 4:34 pm
I'm getting errors playing a recent set of files that were just added to the library. Other things play fine. The flacs have been checked and play fine. This occurs with both the web player and mobile (android). Same error everytime. The file shows up in the player but there is no sound and the timer does not move. Most other files play fine. This seems to be limited to about 5 albums I added a few nights ago.
12:28:09 PM EDT] INFO PlaylistInputStream jbraveman listening to "Led Zeppelin - 1975-03-17 Seattle, USA SBD\lz1975-03-17.sbd.evsd.dadgad.d01t01.flac"
[6/13/11 12:28:09 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-i] [\\Media-pc\g\Library 1\Led Zeppelin - 1975-03-17 Seattle, USA SBD\lz1975-03-17.sbd.evsd.dadgad.d01t01.flac] [-v] [0] [-f] [wav] [-]
[6/13/11 12:28:09 PM EDT] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-b] [160] [--tt] [Rock And Roll] [--ta] [Led Zeppelin] [--tl] [1975-03-17 Seattle Center Coliseum - "Haven't We Met Before"] [-S] [--resample] [44.1] [-] [-]
[6/13/11 12:28:09 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) c:\subsonic\transcode\lame: excess arg Before
I rebooted the server and this did not help.
I'm running this:
Version 4.4 (build 2172) – February 6, 2011
Server jetty-6.1.x, java 1.6.0_18, Windows 7 (205.2 MB / 481.8 MB)
jbraveman
Postby GJ51 » Mon Jun 13, 2011 4:42 pm
What are the transcoding settings?
Were the recently added files ripped with the same software/settings as the rest of your files?
Postby yourlord » Mon Jun 13, 2011 5:00 pm
It looks like your FLAC comments may contain quotes.. That could be causing a problem..
If you have metaflac installed try listing the comments with this command.
metaflac --list --block-type=VORBIS_COMMENT example.flac
replace example.flac with the file you were trying to play in the previous logs.
post the output here for us.
yourlord
Postby bushman4 » Mon Jun 13, 2011 6:48 pm
He is right... you have an Album tag set to:
...including the quotes...
Another option is to just remove the tag pieces from the transcoding options... ie, the "--tt %t --ta %a --tl %l" pieces...
But "yourlord"'s suggestion is better... fix the offending files with a tag editor. Maybe even Subsonic's built in tag editor.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby jbraveman » Mon Jun 13, 2011 7:20 pm
That worked. The subsonic editor didn't seem to work, but mp3tag took care of the problem. I didn't realize quotes were a problem. They don't seem to cause trouble in other players.
Thanks.
Interesting that quotes in the track title don't cause a problem.
3:29:38 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) TITLE : "Don't Hang Off The Balcony/My Dog Has No Nose"
jbraveman
