Any way to start over from the beginning?
Postby PowPowPow » Fri Jun 17, 2011 2:04 am
It looks like my problem:
http://forum.subsonic.org/forum/viewtopic.php?t=7006
may be beyond fixing.
Is there any way to start over from the beginning with Subsonic on my Mac? Uninstalling and reinstalling hasn't worked. Any files I need to edit or delete that I'm overlooking?
PowPowPow
Postby bushman4 » Fri Jun 17, 2011 11:42 am
On windows, Subsonic creates a folder in the root of the system drive that contains all of the settings and database and such. I can't speculate as to where that folder is on a mac, but it has to exist.
I would track that folder down, and then uninstall, delete the folder, and reinstall.
HTH,
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby GJ51 » Fri Jun 17, 2011 6:50 pm
I'm not a Mac guy either, but seeing as the Mac guys aren't responding, I seem to remember that on the Mac there is a /var directory that I think stores the Subsonic information. Again, it's just a guess on my part remembering other posts I've read. You should be able to search and find the instructions you need as I'm almost certain they have been discussed previously.
Edit: http://forum.subsonic.org/forum/viewtop ... +directory
Please notice:
o Installs Subsonic application in /Applications/Subsonic.app
o Installs other files in /Library/Application Support/Subsonic/
o Uses port 4040 by default.
o To change port number or other basic settings, edit /Applications/Subsonic.app/Contents/Info.plist
o For trouble-shooting, start /Applications/Subsonic.app/Contents/MacOS/JavaApplicationStub in a terminal and look at logging.
This is from the Tutorial section at the link above. HTH
Postby PowPowPow » Sat Jun 18, 2011 12:09 am
OK, problem solved. Deleted the /Library/Application Support/Subsonic/ folder and reinstalled. I was poking around in the wrong Library folder.
Many thanks. You are both gentlemen and scholars.
PowPowPow
Users browsing this forum: No registered users and 42 guests
