Subsonic 3 Android client and navigation etc. other sounds
Postby oshogg » Mon Jul 25, 2011 5:20 pm
I have Subsonic 3 Android client - which is working very well for the most part. The one problem I have is that when I use other application that has audio output (such as navigation route commands for example), and when Subsonic 3 is playing - the navigation commands were not audible. When this happened, I was connected to the Car Speaker system via Bluetooth Audio.
I have HTC EVO 4G (running Sprint's Gingerbread 2.3.3 stock ROM) and I am using the latest Subsonic 3 android client from the Market.
Osho
oshogg
Postby GJ51 » Wed Jul 27, 2011 8:26 pm
Known Android bug.
Postby jeffpetersen » Wed Jul 27, 2011 9:29 pm
jeffpetersen
Re: Subsonic 3 Android client and navigation etc. other soun
Postby bemymonkey » Sat Sep 03, 2011 8:15 am
Are you absolutely sure it's not a Subsonic issue? Other players (PlayerPro, stock) don't have this issue.
bemymonkey
Postby BKKKPewsey » Sat Sep 03, 2011 8:21 pm
I think if you read the link that Jeff posted you will find a number of players are having similar problems.
Postby bemymonkey » Sat Sep 03, 2011 8:54 pm
Doesn't the fact that most/many players have no such problems indicate that the others are simply doing something wrong?
bemymonkey
Postby markgbe » Tue Sep 06, 2011 3:31 pm
Same issue here. Pandora works fine, google's built in music player is fine, along with a few others.
Subsonic and navigation were fine together in android 2.2, so sure it's something that google did in 2.3, but i don't think it's a "bug" per se. Hopefully subsonic can be updated to implement the workaround/fix so that it works well with NAV. If Pandora can do it i'm sure it can be done here too.
markgbe
Postby markgbe » Thu Sep 08, 2011 3:34 pm
and i believe this was just fixed with the new version released yesterday. Can nay other confirm?
markgbe
Postby bemymonkey » Thu Sep 08, 2011 3:41 pm
Why do you believe that? There was nothing in the changelog to suggest it...?
Will try it out in the next few days though.
bemymonkey
Postby markgbe » Thu Sep 08, 2011 6:30 pm
The "Always pause playback on incoming/outgoing call. caught my eye" I tried it myself and nav seemed to work this time. Not sure if it was a fluke, but previously it did the low volume thing 100% of the time.
markgbe
Postby reaper829 » Mon Sep 12, 2011 3:53 pm
Where is the "Always pause playback on incoming/outgoing call" option? I can hear the navigation voice now (It's not really quiet like it used to be), but the music doesn't stop when the navigation needs to speak. Thanks!
reaper829
Postby markgbe » Fri Sep 16, 2011 1:53 pm
Not an options. It was in the changelog in the latest subsonic android client release.
markgbe
